H23A BOGS WHEN ACCELERATING HELP!
Old Apr 8, 2013 | 05:41 AM
h22abb6's Avatar
h22abb6 has disabled reputation
Default H23A BOGS WHEN ACCELERATING HELP!
I just recently did a h23a swap in to my 5th gen prelude im running a 255 fuel pumt with 550 injectors as well as a skunk2 intake manifold.. im having issues when accelerating the engine bogs (feels like misfires) not too sure if anyone has ran into this issue before? also idles really low feels like its going to cut off.. let mek now on your thoughts
Old Apr 8, 2013 | 01:41 PM
Mau5head's Avatar
-RepLegion
Mau5head Mau5head Mau5head Mau5head Mau5head Mau5head Mau5head Mau5head Mau5head Mau5head Mau5head
Default Re: H23A BOGS WHEN ACCELERATING HELP!
Is your ECU chipped and setup to run the 550 injectors? If not there's your problem. Also spray crab/brake cleaner around the intake manifold gasket if white smoke comes out the exhaust you have a vacuum leak. Did you mess with the TPS sensor or map sensor at all? Just retrace your steps its simple to do.
Old Apr 8, 2013 | 02:06 PM
Sounds like it needs a tune.
Old Apr 8, 2013 | 02:07 PM
Kris.Is.Foamin's Avatar
Dickbutt #peentip
This. Why do people add things that aren't needed? 550cc injectors for a stock honda motor? You're probably rolling coal when you get on it.
Old Apr 8, 2013 | 02:47 PM
Mau5head's Avatar
-RepLegion
because shitbox is racebox bro!!!
he need's those 550's to push his 200hp....lulz
colorfulej1
Mar 16, 2013 07:18 AM
eball24
Oct 27, 2010 02:03 PM
Gr0dy
Jun 20, 2010 02:50 PM
foxcf
Feb 17, 2009 04:51 PM
ultra spikey
Apr 22, 2006 05:41 AM
