gsr oil pump on an LS
building my LS and thinkin of upgrading the oil pump, i have heard and read that i can use a GSR oil pump on my LS. is there any aftermarket companies that make a good oil pump for the GSRs that i can use on my LS? or go with OEM oil pump?
jay
jay
Re: gsr oil pump on an LS
Yes you can use the GSR oil on your LS block. It bolts right up.
No need to go aftermarket on an oil pump even if you're pushin over 600whp
Stick with the OEM.
Stick with the OEM.
Nonvtec owns you
jay
jay
What year is your Block? All OBD-II blocks have the same oil pump even the LS. 95 and earlier had different oil pumps, so if this is the case get a GSR/ITR(same thing). They are $120-140 new from acura.
Keep using the gear that is on the crank, no need to replace it.
Bitches get Stitches
Nonvtec owns you
Originally Posted by sk8rmike
the gear is in the pump, not on the crank.
Nonvtec owns you
thanks guys, still need to know if i need the lower timing cover?
no no no, i don't think i'm wording my question the right way....
do i need the gsr timing belt plastic cover that goes over the oil pump and timing belt? or does the LS plastic cover work?
thanks
thanks
Nonvtec owns you
thanks
thanks
