Gs-r Tranny
Old Feb 10, 2003 | 07:50 PM
94b18c1's Avatar
emmett18
94b18c1 has disabled reputation
Default Re: off topic but not...
Originally posted by EEK
0psi or any other honda dealership workers
do you guys car bg synchro shift??? i am in need of some of that juice
what is that?
Old Feb 10, 2003 | 07:56 PM
9civic5's Avatar
DUKE BLUE DEVILS
9civic5 is infamous around these parts9civic5 is infamous around these parts9civic5 is infamous around these parts9civic5 is infamous around these parts9civic5 is infamous around these parts9civic5 is infamous around these parts9civic5 is infamous around these parts9civic5 is infamous around these parts9civic5 is infamous around these parts9civic5 is infamous around these parts9civic5 is infamous around these parts
LMAO! He's gonna pour it in the clutch fluid tank!!
Old Feb 11, 2003 | 06:13 PM
94b18c1's Avatar
emmett18
According to the dealer on the b18c1 the fill plug is under the car a lil higher than the drain plug, and i have to squeeze the engine oil in with a tube and a pump.
Old Feb 12, 2003 | 08:51 PM
miahmouse's Avatar
miahmouse is an unknown quantity at this point
Yep. Supposedly you can remove the speedo sensor and fill from there also. And it might not make much of a difference, but just use the Honda MTF for peace of mind(they say 10w30 if not available, but then again how frickin far away is the nearest honda dealership...).
The check/fill plug is on the right hand side, directly behind where the axle goes in. The drain plug is almost directly underneath where the axle goes in (look for the bolt that doesn't go all the way through.
edit... almost forgot...... 2.3 quarts of fluid. Should fill till it starts to come back out (to bottom rim of fill/check bolt).
Old Feb 13, 2003 | 09:49 AM
94b18c1's Avatar
emmett18
thanks
John M
Want to Buy / Trade ARCHIVE
Jul 28, 2007 08:32 PM
chirp the 1-2
Sep 30, 2004 07:23 AM
