gas mileage problem.
Old May 26, 2004 | 09:46 AM
urvtecs2slo's Avatar
i like prom.
Default gas mileage problem.
when i first got my car (96 dx civic hatch) i got good mileage (compared to my previous vehicle). i was getting around 230-240 per tank. now the past couple of tanks have taken a shit. last time my fuel light came on, i tried to run it longer just to make sure it wasnt a gauge problem. that didnt work, because i ran out of gas. i got around 196 on that tank. and today, my fuel light just came on again, and ive only got 173 miles on the tank. id rather not run it down again. so if anyone has any helpful insight as to why my car is being gay, let me know.
thanks in advance.
Old May 26, 2004 | 09:48 AM
Hart-n-Sol's Avatar
To the future...
Hart-n-Sol Hart-n-Sol Hart-n-Sol Hart-n-Sol Hart-n-Sol Hart-n-Sol Hart-n-Sol Hart-n-Sol Hart-n-Sol Hart-n-Sol Hart-n-Sol
Default Re: gas mileage problem.
when's the last time u gave it a good tune up? i'd start there with plug's and all the little cheap things.
Old May 26, 2004 | 09:49 AM
i like prom.
i got the car early february. by the end of feb, i had replaced the cap/rotor, plugs, and wires.
Old May 26, 2004 | 09:52 AM
CHAHONDA's Avatar
corona connessuer
thanks in advance.
give it a tune up and replace/clean your air filter. a dirty air filter will give you terrible milage
Old May 26, 2004 | 09:53 AM
CHAHONDA's Avatar
corona connessuer
your o2 sensor could be going bad as well
i like prom.
you think i should try changing plugs again? or should i be straight with my 3 month old plugs?
and my filter isnt dirty. however, ill give it a good clean just to double check.
keep the advice coming, thanks.
Old May 26, 2004 | 09:57 AM
B16ASilverHonda's Avatar
FredVegas
B16ASilverHonda has a spectacular aura aboutB16ASilverHonda has a spectacular aura about
check your o2 sensors, your plugs should be good, unless you didnt use NGK's and all OE Wires, Cap, & Rotor. Replace your fuel filter, see if that helps
Old May 26, 2004 | 11:59 AM
Iceman05's Avatar
I <3 BOOST
Iceman05 is an unknown quantity at this point
deff check the O2 sensors!
Old May 26, 2004 | 12:00 PM
Iceman05's Avatar
I <3 BOOST
does the CEL come on for any other probs? (ie: rich condition)?
Old May 26, 2004 | 01:09 PM
ritz's Avatar
thanks in advance.
Damn Leigh, how big is your tank.
I get like 240 and that's when I get on it a lot.
