fuel pumps
Old Feb 20, 2003 | 07:32 PM
g S x's Avatar
RIP Chris Schader
g S x g S x g S x g S x g S x g S x g S x g S x g S x g S x g S x
Default fuel pumps
I am planning on buying a Walbro 255lph fuel pump but i need help deciding if I should get the high pressure or low pressure pump. After the pump I will buy a S-AFC so if you have one for sale let me know. Then 560cc injectors. thanks.
Old Feb 20, 2003 | 07:51 PM
Mr.2's Avatar
i probably hate you
Mr.2 is infamous around these partsMr.2 is infamous around these partsMr.2 is infamous around these partsMr.2 is infamous around these partsMr.2 is infamous around these partsMr.2 is infamous around these partsMr.2 is infamous around these partsMr.2 is infamous around these partsMr.2 is infamous around these partsMr.2 is infamous around these partsMr.2 is infamous around these parts
when buying a fuel pump you want one that will do a little more than needed as a margin of safety. i dont know about your setup, what your fuel requirements will be, what your applicaiton is, etc. But, I know that Walbro makes standard and high pressure pumps. Since your going to be going with larger injectors and the afc you will obviously have a higher flow requirement. Due to this you will want to go with the high pressure because it is more likely to be able to keep up with the new requirements than the standard one. So go with the high pressure.
Old Feb 20, 2003 | 07:57 PM
g S x's Avatar
RIP Chris Schader
do you think i will need to get a FPR
Old Feb 20, 2003 | 08:00 PM
Mr.2's Avatar
i probably hate you
a rising rate fpr is never a bad idea
Old Feb 20, 2003 | 08:13 PM
Mr.2's Avatar
i probably hate you
i would recomend looking around on the dsm boards and finding people that have a similar set up to you to see what they are running. copying off someone elses success is allways a good way to go.
Heat's Avatar
HAM
Heat Heat Heat Heat Heat Heat Heat Heat Heat Heat Heat
high pressure + fpr
stock fpr can handle up to about 190lph
Old Feb 21, 2003 | 07:43 AM
MORE IMPATIENT's Avatar
DESTROYS DONUTS !!
i was always under the assumption that dsm's ran really low fuel pressure because pat would flip out everytime i told him what fuel pressure i was running, and his fuel pump lasted one week in my car.........
Old Feb 21, 2003 | 10:51 AM
05DC5's Avatar
I'll be back soon...
05DC5 can only hope to improve
ZEX Fuel Pump is good. Support up to 600HP!
Old Feb 21, 2003 | 01:05 PM
DESTROYS DONUTS !!
thats all good, but id like to know what constant fuel pressure it can run at efficiently, do you happen to know ?........under boost and 10 psi im supposed to be running in the 120psi fuel pressure range , i need something that can withstand that....anybody got any info on fuel pumps........
Old Feb 21, 2003 | 01:07 PM
DESTROYS DONUTS !!
and i have a walbro 255........the inline fuel pump i had before worked well but couldnt really boost to much cause its flow capacity, so i took it out and have this pump in now, but fuel pressure drops from 120 to 90 under boost, i go lean, its not supposed to do that.............hahah........
