Fuel injectors for ka240de
IVe been through about an average of 1injector per 2months,, What is the problem, ive tried the basics but what could be some possibilites ??? bad fuel rail or something ? Please help and throw out some possibilities
is it the same injector? I had 2 injectors go bad on me(same one) so I isolated the ground wire and it never gave me or the new owner another issue.
also are you replacing the crapped out injectors with more used ones?
Is the injector that goes bad always in the same spot?IE: (Injector #1,2,3,4? )If it is, you should check resistance of the wires going to the injector harness. Also check the ohms(resistance) of all the injectors. Also like Spindrift said; are they new or used injectors you're replacing them with?
bringing back an old thread,, ya their new ones im replacing them with,, and it varies but it almost always the #1,3,4 injectors... OHh and they all malfunction because of the bottom oring like being sliced apart, maybe bad fuel rail ??
haha, definitely the issue man. Put some vaseline or something on the o-rings before you put your new injectors in, problem solved. Theyre tearing as you put them in cause there a snug fit and theyre dry, you get the idea.
Now stop fuckin shit up
haha alright ya i got some ,silicon think it was, for the last o-ring no the new injector and its working good !!! and ya fucking shit up is what i do best,
Lookinaround
Nov 8, 2008 12:47 PM
rob42386
Want to Buy / Trade ARCHIVE
Apr 13, 2008 06:32 PM
