Firewall Grommets...
Old Feb 7, 2011 | 05:51 PM
dXXX96civic's Avatar
make 7 UP yours
dXXX96civic has a reputation beyond reputedXXX96civic has a reputation beyond reputedXXX96civic has a reputation beyond reputedXXX96civic has a reputation beyond reputedXXX96civic has a reputation beyond reputedXXX96civic has a reputation beyond reputedXXX96civic has a reputation beyond reputedXXX96civic has a reputation beyond reputedXXX96civic has a reputation beyond reputedXXX96civic has a reputation beyond repute
Default Firewall Grommets...
Found some info and wanted to share
Normally find them in stock at: http://www.hondapartsnow.com/interio...a~grommet.html
Just search and order, good information for someone shaving the firewall that does not have the time and tools to weld it right away but still want a temporary (or permanent) solution that looks clean
Enjoy
Old Feb 7, 2011 | 08:03 PM
Default Re: Firewall Grommets...
I'll sticky this for now.
Old Feb 7, 2011 | 09:54 PM
jdm ek 9's Avatar
jdm ek 9 has disabled reputation
Thank a lot I have been looking for these
Old Feb 16, 2011 | 07:26 PM
ILOVEHATERS's Avatar
V6 POWERED CIVIC
ILOVEHATERS has disabled reputation
Wish I would have went with this instead of welding the holes closed. Like the looks of it a lot
Old Feb 18, 2011 | 02:45 PM
make 7 UP yours
I think if you weld them all shut you should still just plug these holes and get a larger piece to flatten it all out and make it smooth instead of patching each one
Old Apr 2, 2011 | 03:43 PM
Project "H"'s Avatar
Project "H" has disabled reputation
good find ive been wondering if they made delets for these spots mainly to take out my a/c lines
Old Apr 2, 2011 | 04:09 PM
dru's Avatar
dru
GUIBO!?
dru dru dru dru dru dru dru dru dru dru dru
does honda (or another any other make for that matter) have sites like realoem.com or bmwfans.info? makes it real easy to do part number searches
Old Apr 2, 2011 | 04:26 PM
I usaully use www.hondapartsdeals.com to look up part numbers
Old Jun 26, 2012 | 05:05 AM
kadafiz's Avatar
kadafiz has disabled reputation
would the circular one work for cruise control delete?
Old Aug 1, 2012 | 05:57 PM
TNGChris's Avatar
I've just used a grommet from Lowes' hardware section to fill the cruise cable hole.I believe it was 1" diameter,but you should definitely measure to be sure.
As far as that goes,the OEM stuff is nice for the oblong holes like the A/C or harness holes,but for regular 3/4",1" or whatever size round holes,any hardware store will have grommets for probably 1/10th the price,and with no wait.
