EXTREMELY WEIRD PROBLEM!?!
Old May 6, 2008 | 03:56 PM
Naptime's Avatar
TEAM VAJJ
Naptime Naptime Naptime Naptime Naptime Naptime Naptime Naptime Naptime Naptime Naptime
Default EXTREMELY WEIRD PROBLEM!?!
/thread
thanks for the help guys
Old May 6, 2008 | 04:12 PM
VB2NER's Avatar
has a huge dong
Default Re: EXTREMELY WEIRD PROBLEM!?!
that is weird?
Old May 6, 2008 | 04:23 PM
tabbsilverado's Avatar
tabbsilverado has disabled reputation
you need to check the switch in front of your brake pedal that actually sends the power to the lights when you depress the pedal. these switches are known to go bad every once in a while. if it has gone bad, then it will either send power all the time like your problem, or the lights wont go on at all.
Old May 6, 2008 | 04:28 PM
basketthis69's Avatar
All stock. No modify
basketthis69 has disabled reputation
+1
Old May 6, 2008 | 04:47 PM
VB2NER's Avatar
has a huge dong
how would he know its bad? Is it just a basic switch, like what does it look like?
Old May 6, 2008 | 04:51 PM
you would have to test with a multimeter or you would see it visibly broken
Old May 6, 2008 | 04:52 PM
F4Ryder's Avatar
F4Ryder has disabled reputation
yo there is a piece in the brake pedal that catches the brake switch and most likely it has dry rotted and fekll out so if you look at the end of the brake pedal where the brake switch is there will be a small hole you have to block that hole off and the brake light will work properly again
Old May 6, 2008 | 05:01 PM
Naptime's Avatar
TEAM VAJJ
thanks for the advice. it is too dark to check it now, but i intend to do it in the morning. i will post the results. But i am also interested in why the harnesses look the way they do..on my car and the one at the junkyard. Kinda weird both cars looked the same..
Old May 6, 2008 | 05:19 PM
tail_ler's Avatar
tail_ler is an unknown quantity at this point
i dont understand how u could pull the fuse and have it stay on, sure u didnt pull the wrong fuse. But i agree with the problem being the switch
Old May 6, 2008 | 05:20 PM
because they are old and worn. the "grease" you are seeing stops corrosion and doesn't hinder the performance of the electricity. so, it's a good thing. nothing looks wrong with your harness other than the wire that's pulled out (which has been replaced, i know)
