engine size question
I am fully aware that displacement is more complicated then bore x stroke x displacement, and also more complicated then (pi/4) x bore^2 x stroke x #cylinders. I am also fully aware of the entire gay ass thread a few weeks ago.
I was trying to offer a simple answer to a simple question, not create another playground for your faggotry.
Please keep in mind that I too, am far more intelegent then you.
Its amazing how quickly you turn into a little bitch when asked to give a real answer to a question.
Litres of an engine is the space the motor displaces within the block. As stated before, stroke x bore x # of pistons = engine displacement. Someone touched on how much air the motor can flow (displace), that is flow capicity which is linked to static and dynamic compression. Team-Integra.net has a great set of articles for you to read, no searching needed +1
Displacement is defined as the amount of air an engine can move on one complete cycle at 100% VE.
There is no twisting it around or adding things or taking away things. That is the definition of displacement....in automotive terms.
If you use a turbo to CRAM air into the motor then it will "pump" more air in less displacement.
