engine overheating......almost
Old Nov 2, 2006 | 12:09 PM
nuke0907's Avatar
Never Blend In
nuke0907 has a reputation beyond reputenuke0907 has a reputation beyond reputenuke0907 has a reputation beyond reputenuke0907 has a reputation beyond reputenuke0907 has a reputation beyond reputenuke0907 has a reputation beyond reputenuke0907 has a reputation beyond reputenuke0907 has a reputation beyond reputenuke0907 has a reputation beyond reputenuke0907 has a reputation beyond reputenuke0907 has a reputation beyond repute
Default engine overheating......almost
i was sitting in a drive thru today when i rolled my window down it sounded almost like a coffe maker. i turned the radio down and found out it was my car. its a 95 240SX BTW. i looked at my temp gauge and it was getting near the hot mark. i then turned the engine off, until the car in front of me started moving. once i did that the sound was almost like a drain sound and when it stopped, i started it back up. it was only off for a few seconds. but then everything was back to normal.
i've had this happen before to a way worse degree. it turned out being the thermostat getting stuck. since it has happened before should i worry about it more or should i just keep driving it.
Old Nov 2, 2006 | 12:11 PM
FastPrelude420's Avatar
FastPrelude420 has disabled reputation
Default Re: engine overheating......almost
check fluid level
Old Nov 2, 2006 | 12:20 PM
Fobby's Avatar
Classified Moderator
Fobby Fobby Fobby Fobby Fobby Fobby Fobby Fobby Fobby Fobby Fobby
possible air in coolant system....happened to me in my s14
Old Nov 2, 2006 | 12:24 PM
nuke0907's Avatar
Never Blend In
do you think when i shut it off, the noise was air coming out, or do i need to drain it and refill it?
Old Nov 2, 2006 | 04:35 PM
Spindrift's Avatar
psycho jungle cat
the noise was coolant being sucked from your overflow into your radiator. how long ago did you replace your thermostat?
Old Nov 2, 2006 | 05:59 PM
nuke0907's Avatar
Never Blend In
about a year ago
Old Nov 3, 2006 | 05:35 PM
EvolutionBoostin's Avatar
Currently N/A
EvolutionBoostin is an unknown quantity at this point
Something may be causing your thermostat to go bad, or you have a low fluid level (which means check for leaks). So basically check your fluid, and if it's good then replace your t-stat again.
Old Nov 4, 2006 | 08:36 AM
atmdc's Avatar
やくざに成りたい
atmdc has disabled reputation
im going to go with air in the system, if you didnt let the air out when you filled up the coolant, a whole lot of problems can arise such as overheating, looping idle, and for me i had 2 radiators pop
Old Nov 4, 2006 | 09:01 AM
vasponger's Avatar
Captain night owl
vasponger vasponger vasponger vasponger vasponger vasponger vasponger vasponger vasponger vasponger vasponger
yeah ive had a lot of problems with overheating. replace tstat, go get it flushed
Old Nov 4, 2006 | 11:41 AM
Cpt. Non-Spell's Avatar
Speak&Spell Anyone?
Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell
Or try to burp the coolant system. Pretty much what fobby said.
