Electrical Problem 99 Civic si
Old 05-13-2010, 05:51 PM
RoyB93's Avatar
RoyB93 has disabled reputation
Default Electrical Problem 99 Civic si
today while i was driving i noticed my foglights, and climate control were not working. I tried disconnecting the battery, and putting it back, but still it didnt work. The only thing i have done recently was try to get the CEL code with the paperclip method, which didnt work either, is there any way i could have screwed something up? I'm thinking it may be a fuse, but i didnt see any that looked blown, and if it is a fuse, which one is it most likely to be?
any info helps, thanks
RoyB93 is offline
Old 05-13-2010, 06:02 PM
woot! :D
The Guy's Avatar
The Guy is infamous around these partsThe Guy is infamous around these partsThe Guy is infamous around these partsThe Guy is infamous around these partsThe Guy is infamous around these partsThe Guy is infamous around these partsThe Guy is infamous around these partsThe Guy is infamous around these partsThe Guy is infamous around these partsThe Guy is infamous around these partsThe Guy is infamous around these parts
Default Re: Electrical Problem 99 Civic si
Well, I'm not too familiar with civics, but on the drivers side under the dash there is a panel that you can pull off. On the back it says which fuses are what. The fuse box is under the panel. Check those. If not there, there may be a couple of fuse boxes under the hood. If i remember correctly, its right in front of the battery. A fuse that is blown might be there. Thats probably your best bet fuse wise for the lights.
The Guy is offline
Old 05-14-2010, 04:41 PM
RoyB93's Avatar
yep, there was a blown fuse on the drivers side fuse box, everythings working perfect again. thanks
RoyB93 is offline
Old 05-14-2010, 06:39 PM
woot! :D
The Guy's Avatar
No problem, man.
The Guy is offline
