electrical help please
Old Jul 15, 2008 | 07:09 PM
89Leg2a94Teg's Avatar
89Leg2a94Teg has disabled reputation
Default electrical help please
i just put a cd player in.
im a beginer at this and i krimped the wires and taped them as good as i can.
im guessing tape came off and a wire touched metal because something sparked while i was driving, and my dash lights, back lights, and front left lights went out.
anyone know what i need to do to fix this?
did i blow a fuse?
feed back would be appreciated, thank you
Old Jul 15, 2008 | 07:19 PM
ethan82000's Avatar
ethan82000 has a reputation beyond reputeethan82000 has a reputation beyond reputeethan82000 has a reputation beyond reputeethan82000 has a reputation beyond reputeethan82000 has a reputation beyond reputeethan82000 has a reputation beyond reputeethan82000 has a reputation beyond reputeethan82000 has a reputation beyond reputeethan82000 has a reputation beyond repute
Default Re: electrical help please
yes..u probably did blow a fuse
Old Jul 15, 2008 | 07:20 PM
are those the little clips that go in that fuse box under driver side. if so, whicih ones would ne replacing? will a blown fuse be burnt?
Old Jul 15, 2008 | 07:42 PM
basketthis69's Avatar
All stock. No modify
basketthis69 has disabled reputation
it may be burnt looking. the best thing to do (unless you have a multimeter, which in your case is highly unlikely considering the type of thread you have made) is remove them one at a time and look to see which one is bad. once you find the bad one, replace it with a good one of the same amperage. you can go to any parts store and ask them for the same exact replacement fuse. you can take it out once you find it as it is serving no purpose in your vehicle, so don't worry about that.
i suggest before you do replace the fuse, go get some electrical tape (the good kind) and tape up those connections behind you radio really well so that they never touch again. then replace the fuse.
Old Jul 15, 2008 | 08:07 PM
wow your amazing. your post really helped. thanks a lot man!
Old Jul 15, 2008 | 08:09 PM
LOL!! sarcasm much?
Old Jul 16, 2008 | 10:40 AM
lol no i was being serious, now i need a fuse box diagram =[
Old Jul 16, 2008 | 12:07 PM
98formulaLS1's Avatar
98formulaLS1 will become famous soon enough
do you now know which fuses actually go to the radio, dash light, rear tails, and front lights? do you have an owners manual?
Old Jul 17, 2008 | 07:55 AM
no i do not. i only know basics of cd player
Old Jul 17, 2008 | 08:55 AM
CHAHONDA's Avatar
corona connessuer
where are you located?
