ek makes weird vibration towards the front of car when releasing clutch in 1st and 2n
Is it only when releasing the clutch or is it also when the clutch is completely released and driving while in gear?
This is a good thought. I've seen motor mounts cause a vibration in the pedal itself. Sounds to me like you got "clutch chatter". Was the flywheel machined or replaced when the clutch was replaced?
i think u might be right, saw some videos you ytube on clutch chatter and mines is showing similar signs. so is this ok to drive with daily? or should i replace it asap?
Just try to figure out how to drive the clutch to where it's not so harsh. Over time the chatter will lessen but will prob. never go away totally. It should be fine, but just realise where the stresses are being transfered. clutch disk, pressure plate, flywheel and even engine, trans. and even dash... haha like street driving a stage 3 clutch with solid motor mounts. Chatter and vibrations happen...
