ecu help.
ecu help.
I am currently using a b16a but I'm running obd0 injectors with the resister box but I'm running the p2t ecu and I Rev bounce at 7k my friend said I should use a obd1 ecu with a base map my question is can I run an obd1 ecu on my obd2a motor? What will I have to convert ect. The car was previously running obd1 I just blew the ls/v and just got what I could so everything is plugged up except the o2 sensor but I still have it its just not plugged up
Re: ecu help.
No wonder it's not running right. I'm glad you feel confident about beating on it without worrying about using all of the critical sensors. Good luck with that.
VaDriven Mayhem
VaDriven Mayhem
Re: ecu help.
Then again, the lack thereof explains a lot of Honda owners
