Easiest way of removing tint
Old May 27, 2008 | 12:09 PM
SortaFlush's Avatar
Slammedxpert
Default Re: Easiest way of removing tint
Originally Posted by F4Fresh
just make sure your fronts arn't too dark. you should be ok from there.
if you need help also bro i got some good knife blade scrapper tools(one they use to take inspec stickers off with).
just stop by.
Alright Frankie Fraaaaaaaaaash. I'll call you in a little bit, I would just go up to my shop but its my day off and they always pull me off what I'm doing...so thats a no no.
legal limit is 50% front 35% rear and Back window is 20%
Good luck
Old May 27, 2008 | 12:13 PM
F4Fresh's Avatar
Ammo Pusher
F4Fresh F4Fresh F4Fresh F4Fresh F4Fresh F4Fresh F4Fresh F4Fresh F4Fresh F4Fresh F4Fresh
bring all your shit tho your using,i might not have it!
frankie
Old May 27, 2008 | 12:34 PM
DickButt's Avatar
DEY SEE ME TROLLIN
DickButt DickButt DickButt DickButt DickButt DickButt DickButt DickButt DickButt DickButt DickButt
windex may work well, but tint remover works better. They sell it at advanced and it usually even comes with one of those razor blaze scrapers.
Old May 27, 2008 | 09:34 PM
JETSWU87's Avatar
OM NOM NOM E30
JETSWU87 JETSWU87 JETSWU87 JETSWU87 JETSWU87 JETSWU87 JETSWU87 JETSWU87 JETSWU87 JETSWU87 JETSWU87
remove tint(film)
Use steel wool(very fine) and simple green for the glue.
Works quickly and helps get rid of the nasty smell at the same time.
Old May 27, 2008 | 10:11 PM
1slowb18's Avatar
1slowb18 is an unknown quantity at this point
i just paid a $211.00 fine for my tint, $125.00 for the fine and $86.00 processing fee, i had 33%
the limit is 50%, but i been told by my neighbor( a state trooper) that you should get a 7% leeway so you should be able to go as low a 43% without getting pulled, or you can be a real rebel and not get your windows tinted
Old May 27, 2008 | 10:12 PM
1slowb18's Avatar
and GL with court,hopefully you don't get found guilty and raped with a huge fine
Old May 27, 2008 | 11:13 PM
Kris.Is.Foamin's Avatar
Dickbutt #peentip
Tint film is 2 layers- the outside layer comes off pretty easy- the glue, not so much.
let it sit in the sun and get nice and toasty.
Old May 27, 2008 | 11:42 PM
CAPSLOCK's Avatar
CAPS LOCK BABY
CAPSLOCK CAPSLOCK CAPSLOCK CAPSLOCK CAPSLOCK CAPSLOCK CAPSLOCK CAPSLOCK CAPSLOCK CAPSLOCK CAPSLOCK
i took mine off when i had my srt, it was snowing outside and i just cracked the window so i could get to the top and scraped it with a razer blade, took me less than 5 mins to do all 4 windows. i suggest that way, once you get a edge it should peel unless they used some crazy glue to put it on.
Old May 28, 2008 | 06:02 AM
RPRacing's Avatar
Huntin Dropa ForLife
RPRacing has disabled reputation
take some mildly diluted ammonia, 5:1 (ammonia to water). spray the windows that you want the tint off of. put black plastic trash bags on the window as if you were gluing them to the window. covering as much as you can. leave the car on full blast heat and set it in the sun for a couple hours. come back and you'll notice how easy the tint film comes off. the reason for the heat (as long as you pull the film off slow when you go to remove it) is that it makes the glue really soft so you have much less (glue) to scrape and steel wool once the film is all off.
