e brake light coming on
Old 05-05-2009, 10:09 AM
emgjsdk1's Avatar
emgjsdk1 emgjsdk1 emgjsdk1 emgjsdk1 emgjsdk1 emgjsdk1 emgjsdk1 emgjsdk1 emgjsdk1 emgjsdk1 emgjsdk1
Default e brake light coming on
i was driving home (93 del sol si)
and i was at a stop light, and my e brake light came on.
and it stayed on for a min, and when i saw that it came on i stopped at a gas station to turn the car off and turn it back on to see if it would go away but it didnt, so i head home and it turns off and then i turn onto my road and it comes back on and no the e brake isnt up or anything. i took up my center consol and checked if the sensor was unplugged or loose and its fine any other ideas?
emgjsdk1 is offline
Old 05-05-2009, 10:12 AM
el oh el
JAPCO's Avatar
JAPCO JAPCO JAPCO JAPCO JAPCO JAPCO JAPCO JAPCO JAPCO JAPCO JAPCO
Default Re: e brake light coming on
Put the e-brake down
JAPCO is offline
Old 05-05-2009, 10:13 AM
emgjsdk1's Avatar
help ful info
im not a retard the e brake is down
emgjsdk1 is offline
Old 05-05-2009, 10:14 AM
PlasticHero's Avatar
PlasticHero is an unknown quantity at this point
Check the level of brake fluid in the brake fluid reservoir, it may be low. This will also cause the light to come on.
PlasticHero is offline
Old 05-05-2009, 10:17 AM
emgjsdk1's Avatar
it is low
i already know but thanks im gonna pick up a bottle of dot 3 and see if it helps
emgjsdk1 is offline
Old 05-05-2009, 11:42 AM
Brown Water
Livin_Legend's Avatar
Livin_Legend Livin_Legend Livin_Legend Livin_Legend Livin_Legend Livin_Legend Livin_Legend Livin_Legend Livin_Legend Livin_Legend Livin_Legend
fluid level is low
Livin_Legend is offline
Old 05-05-2009, 11:50 AM
Slammedxpert
SortaFlush's Avatar
it is low
Your not going to "See if it helps"
it will help.
SortaFlush is offline
Old 05-05-2009, 11:59 AM
Chicken Little
ruger988's Avatar
Side note to that....brake fluid doesn't just disappear. Before just dumping new fluid in make sure you don't have a leak (very unlikely without you knowing about it) or the much more likely case, your brakes are old as fuck and need to be replaced, and you might s well flush the fluid while you're at it versus just topping it off.
ruger988 is offline
Old 05-05-2009, 12:06 PM
Slammedxpert
SortaFlush's Avatar
Or his brake fluid has moisture in it and it has flashed a time or two.
Old 05-05-2009, 12:07 PM
Chicken Little
ruger988's Avatar
Im willing to bet the kid probably needs brakes regardless given his posts..probably been driving the piss out of the car for a year or two and given them no second thought, could be wrong..but knowing this board...I' thinking it's a safe guess.
ruger988 is offline
Quick Reply: e brake light coming on
