del sol with gsr swap spuders after 2000rpm
Old Feb 8, 2008 | 07:54 PM
jdmontheway's Avatar
jdmontheway has disabled reputation
Default del sol with gsr swap spuders after 2000rpm
what can it be 97 swap with blox manifold it happened after the install
Old Feb 9, 2008 | 12:12 AM
93turboeg's Avatar
93turboeg has disabled reputation
Default Re: del sol with gsr swap spuders after 2000rpm
make sure your intake manifold gasket isnt leaking.
also is there a check engine light on?if so check the code and go from there.
check this link to make sure you did everything right.
http://www.ff-squad.com/tech/howto/sk2manifold/
goodluck.
Old Feb 9, 2008 | 02:13 AM
thermal's Avatar
TurboPipingSystems
check your TPS and Map sensor plugs... decode if there is a CEL.
Old Feb 11, 2008 | 02:12 PM
crxtyper's Avatar
crxtyper is an unknown quantity at this point
reset your ECU...check what they said also...if your close to DC I can check out for you at no cost..
robb1887
May 4, 2008 05:40 PM
90singleslam
Sep 6, 2007 03:13 PM
Zen
Oct 10, 2003 06:24 AM
