DA motor swap
I'm thinking about getting a da soon, and im thinking either H22a or B18c1.
What parts would i need to do either set up, and which do you think will be easier/cheaper/more worth it in the end?All help is appreciated.
The GSR would be the better way to go.Here's everything you need. http://www.hmotorsonline.com/shop/sc...age&item=30008
the da im looking at is a 93 i heard that if i get the 93-95 gsr motor all i'll need is "motor,trans,ecu,axles,halfshaft and shift linkage" but the H22 if its 92-96 i will need "motor,trans,ecu,shift linkage,94+ integra axles,motor mount kit,& 94+ integra gsr wiring harness". i got this off of jspecautosports.com,will that be everything i need ? thanks again for all the help.
IF the DA still has the stock motor still in it all you need to do the GSR swap would be the longblock and the ecu, you can use your stock wiring harness and wire in a few things ( vtec, knock sensor, IAB's etc.) You can also use your stock trans but it is not the best all motor trans to run, the GSR trans would be better if you plan on staying all motor. Your stock shift linkage will work also with the GSR as well as the axles. I vote H22, but if this is your first swap stick with the GSR its easier and if you car already has the stock motor in it then it would be cheaper.
You can use your harness and modify it to fit the h22 ( longer alternator wires, wire in vtec, etc etc) you can use 94 integra axles if you run h22 inner cv joints not really something alot of people do but it can work. If you need any help with anything ( installing motor , parts, or just plan questions) give us a call at 804 224 9530 Brauning Motorsports.
