D16y7 Oil pan replacement?
i have a stock d16y7 and the oil drain plug is stripped. instead of tapping a bigger bolt, im considering replacing the oil pan.
what all will i need for the swap? oil pan gasket sealer is that it? where could i find the parts, prices, and how much to torque the bolts? what else will have to be removed for repair? rep will be given for actual help. |
Re: D16y7 Oil pan replacement?
Haynes repair manual.
Y7 and Y8 pans are interchangeable. Not with the earlier d's and not sure about the d17's
You got most of it covered. torque from the center and criss-cross out pattern. i can post numbers later. if you need either pan, i have 1 each but im in nova and can ship |
Originally Posted by Laserjock
(Post 6377901)
You got most of it covered. torque from the center and criss-cross out pattern. i can post numbers later. if you need either pan, i have 1 each but im in nova and can ship ill get back to you about possibly picking up the y7 pan |
Originally Posted by The Guy
(Post 6377850)
apply liquid sealant to the 4 points where the half rounds meet the flat sections. 8.7lb/ft on the 6 bolts. forgot the Y5 (HX motors) there are no oil return lines connected to the pan unless added after for turbo appz (word) unless you mean the pickup but you dont need to mess with that. |
Originally Posted by 97Ek_coupe
(Post 6377753)
(Post 6378101)
:facepalm: thank u '10, there were 18 keystrokes in your post - it would have taken 1 keystroke to hit the "back" key
(Post 6379216)
The Haynes manual covers all of that, thank you very much. Im trying to help the guy get more info than just some guys saying a couple of things on the internet. The manual will cover all of it and if he ever needs something else, it will more than likely be in there.
I just post here to increase my post count - not help people. What's your excuse Do not thank me, I haven't given you anything yet |
How about you shut the hell up and do not speak anymore? Telling someone to get a manual for their car is probably some of the more helpful advice you can give. Its not going to be wrong. It is going to be more accurate than some people on the internet trying to recall how to do something they have only done once or have never done. And if anything else comes up, its right there. Sorry I dont have an oil pan for a y7 or 8 i can pull out of my ass and sell to someone. Knowledge is power, and Haynes will give you that knowledge.
(Post 6380734)
(Post 6380734)
everytime you post something in this thread, you show that you're The annoying Guy talking out of your ass so feel free to post again man. I'm sure you'll be back. I copied that info from my 97 Civic Factory service manual. I also have alldata access so if I don't know the answer, I can find it. I won't post anything that is incorrect. Reason I have a Y8/7 pan is I bought 2 blown engines for spares and to rebuild. Don't forget the Y5 pan. + 1 to my post count |
