CRX D series motor questions......
Old Sep 28, 2004 | 04:50 PM
CBR600F4's Avatar
Va Beach Coast Rider
CBR600F4 CBR600F4 CBR600F4 CBR600F4 CBR600F4 CBR600F4 CBR600F4 CBR600F4 CBR600F4 CBR600F4 CBR600F4
Default CRX D series motor questions......
Here's my question: I have a 90 si motor and a 90 dx motor. How hard would it be to put the si head on the dx motor; and what would be the bennies if any?
Old Sep 28, 2004 | 06:10 PM
EvolutionBoostin's Avatar
Currently N/A
EvolutionBoostin is an unknown quantity at this point
Default Re: CRX D series motor questions......
How hard? Easy swap. I don't see any reason to do it unless the si bottom end is bad. I don't know any exact specs, but I've done both and they seem the same. Just my .02
Old Sep 28, 2004 | 06:34 PM
GreySquirrel's Avatar
Got a new name.
GreySquirrel GreySquirrel GreySquirrel GreySquirrel GreySquirrel GreySquirrel GreySquirrel GreySquirrel GreySquirrel GreySquirrel GreySquirrel
a dx bottom and a si bottom are practically the same thing, you won't get any gains at all really. you'd be better off finding a nice z6 or y8 head and do that swap if you want some cheap easy power gains. the real question is, are you doing this in a dx or a si? if it's a dx then you'll need to do the whole mpfi swap and what not. a little more info on what you're looking to do would be real helpful.
Old Sep 28, 2004 | 08:18 PM
Cpt. Non-Spell's Avatar
Speak&Spell Anyone?
Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell
no the dx bottom end has differnet coolant passages than the si... and the cam in the si is mor loppy(sp). to be honest i would just put the whole si motor in the dx and do the harness conversion..... whats up on those springs by the way?
Old Sep 29, 2004 | 04:21 PM
CBR600F4's Avatar
I know the dx bottom end has different coolant line positions and stuff. And the EFI is different as well.
I'm asking cause I wrecked my si. Bought a dx of the same year (1990). My si motor is fine, except for one of the main seals.......leaks some oil. The dx motor doesn't leak at all.
So if I can swap heads right now for nothing, I'd be good to go.different compression should give me some gains as far as I know.
I could put the si motor in; but I'd have to replace the main seal and re-wire the whole damn system. If I do a mini-me I'll have to re-wire as well.
So just changing the head seems like the simplist, cheapest way to go right now.................................
Springs are on the dx right now. If you want them I can still swap them out (again). Just let me know.
Old Sep 29, 2004 | 04:46 PM
xk84f9ds's Avatar
xk84f9ds is an unknown quantity at this point
just put the si cam in it....and take mad weight out and boost it
Old Sep 30, 2004 | 09:16 AM
Currently N/A
Ah ok I understand. You should just put the si head on the dx. It's easy to do and it'll be basically the same as the si. G/L.
Old Sep 30, 2004 | 04:20 PM
CBR600F4's Avatar
Thanx man...................
DORKO
Dec 31, 2005 01:25 AM
