crx b20 swap
Old 06-18-2007, 11:04 AM
  #41
b16 hatch
puaar20's Avatar
puaar20 has disabled reputation
Default Re: crx b20 swap
Originally Posted by important
http://www.50mod.com/fourthgenhatch/mpfi.html
check your injector wiring to the ecu,and to the resistor box,also check your resistor box and dizzy,if the fuel pump does not turn on when you bump the key then it is your main relay,get one from a junk yard if need be,that is the issue you need to worry about first.
ive already changed out the main relay. i had at one point the mian relay would turn on and once the fuel pumnp cut on it was wen my boy was messing with the four main grounds that hook to the themastat houseing.
puaar20 is offline
Old 06-18-2007, 11:06 AM
  #42
important's Avatar
important is an unknown quantity at this point
why are there four ground at the thermostat,that is your problem.are there any ground even on the chasis
important is offline
Old 06-18-2007, 11:11 AM
  #43
b16 hatch
puaar20's Avatar
nah theres four factory grounds that come into one that hook there cas wen i took the modified harness off. they were right there untouched on the stock harness that i put back in. they are the main grounds. and once again any one that can get this runing ill give them everything in my mount thread to do it
puaar20 is offline
Old 06-18-2007, 11:23 AM
  #44
Ghost
MerF's Avatar
I bet people could help you if they could understand you.
Just saying.
MerF is offline
Old 06-18-2007, 11:25 AM
  #45
b16 hatch
puaar20's Avatar
Just saying.
understand me? how can no one understand me. dude stay off my thread
puaar20 is offline
spnamnt
07-19-2008 09:14 AM
SiR2EG6
Want to Buy / Trade ARCHIVE
18
04-01-2008 09:50 AM
F4Fresh
08-20-2005 11:24 PM
Quick Reply: crx b20 swap
