compression test adapter stuck in spark plug socket
Old Aug 25, 2011 | 12:51 PM
98accord1's Avatar
98accord1 is infamous around these parts98accord1 is infamous around these parts98accord1 is infamous around these parts98accord1 is infamous around these parts98accord1 is infamous around these parts98accord1 is infamous around these parts98accord1 is infamous around these parts98accord1 is infamous around these parts98accord1 is infamous around these parts98accord1 is infamous around these parts98accord1 is infamous around these parts
Default compression test adapter stuck in spark plug socket
hi i was doing a compression test with one of my friends gauges and didnt realize that there was an adapter so the adapter is screwed into where the spark plug is supposed to go. anyone know how i can get it out? tried long needle nose pliers but they didnt fit on the side. also tried using a screwdriver and feed it along the sides but that also did not work. can anyone help me?? what do i need to do?
Old Aug 25, 2011 | 01:55 PM
Gen_Crunchytoes's Avatar
i pooped a squirrel
Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes
Default Re: compression test adapter stuck in spark plug socket
Post pics of the gauge. I have an idea depending on how the gauge is built
Old Aug 26, 2011 | 07:22 AM
98accord1's Avatar
Bump... Help!
Old Aug 26, 2011 | 08:28 AM
nftuatn's Avatar
baller/dickbutt#69
He told you to post pics of the gauge...that way we can figure out what needs to be done
Old Aug 26, 2011 | 10:17 AM
98accord1's Avatar
When I get home from work I will
Old Aug 26, 2011 | 10:22 AM
Pele's Avatar
Pele has disabled reputation
Also post up what kinda engine it's stuck in (Or are we assuming it's the 1998 Accord you have listed as your username?)
The retrieval method might be different if it's in a deep tube or on the side of the cylinder head.
Old Aug 26, 2011 | 10:42 AM
98accord1's Avatar
Sorry about the confusion. It's in a d16y7 and it's semi deep
Old Aug 26, 2011 | 11:43 AM
Pele's Avatar
Is the adapter 100% metal or did it have a rubber tube part of it?
Is the adapter broken at all, or did it just come apart from the gauge?
Old Aug 26, 2011 | 12:05 PM
98accord1's Avatar
The adapter is all metal and it just unscrewed.
Old Aug 26, 2011 | 12:13 PM
MICK LVN's Avatar
MICK LVN MICK LVN MICK LVN MICK LVN MICK LVN MICK LVN MICK LVN MICK LVN MICK LVN MICK LVN MICK LVN
Maybe try some thread locking solution. put a couple of drops on the threads of the tester then screw it back in. Give it a little while then try turning it back out.
