compression help
Old Sep 28, 2008 | 06:16 PM
2kSi's Avatar
2kSi has a spectacular aura about2kSi has a spectacular aura about2kSi has a spectacular aura about
Default compression help
PLEASE CLOSE
Old Sep 28, 2008 | 06:43 PM
Jarrod's Avatar
braap braap
Default Re: compression help
Fuck the gasket.
Who installed your block-guard?
Old Sep 28, 2008 | 07:10 PM
2kSi's Avatar
Originally Posted by Jarrod
Fuck the gasket.
the guard not installed yet buddy, everything are in parts not assembled yet, jus need some idea before it come together. and that didnt even help
Old Sep 28, 2008 | 07:11 PM
Audio's Avatar
#Trendy
Audio Audio Audio Audio Audio Audio Audio Audio Audio Audio Audio
A thicker headgasket will lower compression, (.030 is stock honda i believe) Cometic makes em from .026~ to like .120 I think.
But as stated by jarrod id be more concerned about who installed the blockguard and if its dont correctly, they are very easy to mess up.
Old Sep 28, 2008 | 07:43 PM
2kSi's Avatar
dammit ur right it is stock thickness..oh well get low comp piston...and wat is the right way to install the gaurd?? isnt the stock bore 81mm
Old Sep 28, 2008 | 08:22 PM
DeFunk's Avatar
DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk
Not at all is the correct way. Increases cylinder temperatures in the top of the cylinders, limits coolant flow overall which out weighs any gains from it. However, if you're insistent on installing it, having a machine shop inserting it correctly/evenly, boring the cylinders to account for any inconsistent pressure on the cylinders applied by the block guard and then finally decking to ensure a true flat deck surface is maintained after installation. So, as aforementioned in this paragraph, the correct way is not to install one at all. 81mm bore will take a very nice amount of CFM as well as produce a nice amount of power on healthy stock sleeves with a PROPER tuning.
Enjoy.
Old Sep 29, 2008 | 06:10 AM
thermal's Avatar
TurboPipingSystems
Dont mess with a thicker head gasket nor the blockguard.... even stock pistons will be fine for mild boost. Just make sure you get a decent tuning unit....
hey its me
Feb 10, 2009 12:01 AM
watisjdm
Want to Buy / Trade ARCHIVE
Dec 10, 2008 05:25 AM
2-Logicl
Sep 13, 2005 12:35 PM
wld2rde
Feb 9, 2004 04:45 AM
