Clutch Help?
Old Mar 6, 2007 | 12:45 PM
ShaneJeffers28's Avatar
Hatch95gsr
ShaneJeffers28 can only hope to improve
Default Clutch Help?
I walked out to my car and the clutch pedal went all the way to the floor. Ive only had the clutch for two years...so is it possible it could be sopmething else? Thanks. Oh and its a jdm b18c in a 95 civic hatch.
Old Mar 6, 2007 | 01:01 PM
Jakers's Avatar
Jakers is an unknown quantity at this point
Default Re: Clutch Help?
try cutting a hole in the floor to see if you can push it down any further.
or try using your other foot. hope this helps
Old Mar 6, 2007 | 01:10 PM
Hatch95gsr
Ok smarty the clutch won't engage at all..you know what I meant!
Old Mar 6, 2007 | 01:42 PM
tatmonster's Avatar
2.0
check your clutch master cylinder( its beside your brake master cylinder) you might be out of fluid and have to bleed it once you fill it back up. it takes just regular dot 3 brake fluid. hope this helps.
Old Mar 6, 2007 | 02:57 PM
thermal's Avatar
TurboPipingSystems
fluid then bleed....... start from there......
