Civic turns off while driving, Y?
Old Jul 8, 2008 | 01:10 PM
latinflavor469's Avatar
latinflavor469 has disabled reputation
Default Re: Civic turns off while driving, Y?
Originally Posted by aacjohnc
. if it was a fuel pump it would start at the most but will bog down/ turn off if the pump was going bad as soon as u give it gas . get a fuelpump/fuel injector kit to check pressure . jsut did mines this weekend on my silverado. should have around 30-40 psi if im not mistken. if it doesnt have that then u have a bad pump. i sell u my kit i just bought if u need one . 25 dollars and its yous.used for only five min.
I think my friend has the kit. Ima ask him to do it for me.
Thanks for the info guys..
Old Jul 8, 2008 | 01:27 PM
aacjohnc's Avatar
is it throwing any codes?
check engine light on ?
running to lean to rich?
stock motor or is it a swap ?
any mods ?
Old Jul 8, 2008 | 01:32 PM
pt0wn_4door's Avatar
pt0wn_4door has disabled reputation
after cutting off will it start right back up or do you have to wait for it to cool down before it'll restart?
Old Jul 8, 2008 | 01:42 PM
~Josh's Avatar
doesn't like 1911s
~Josh ~Josh ~Josh ~Josh ~Josh ~Josh ~Josh ~Josh ~Josh ~Josh ~Josh
did it shut off while driving or were you sitting at a light?
Old Jul 8, 2008 | 02:18 PM
any mods ?
Check engine light is not on.
Just did a tune up last weekend.
Stock D16 auto motor.
Idk if its throwing any codes.
Old Jul 8, 2008 | 02:26 PM
if fuel system is checked and nothings wrong there try checking the ignition coil and icm.
Old Jul 8, 2008 | 02:34 PM
kseriesdc2's Avatar
kseriesdc2
kseriesdc2 has disabled reputation
I would go with new distributor. They shouldn't cost more than $200. ecu should be good if you're starting right back up.
Old Jul 8, 2008 | 03:09 PM
I was at a light when it shuts off but when I was driving it again it would go around 25mph den it would just slow down and when it stop, it would turn off. Wat I did is stop when its bout to turn off and turn the car off and started it back up so I can speed up and its just going really slow...
Yea it does turn back on rite after
Old Jul 8, 2008 | 03:13 PM
I replace the distributor,alternator, spark plugs,wires, oil and filter
Old Jul 8, 2008 | 08:33 PM
musicmaniac's Avatar
wtb scoobie snacks
musicmaniac is on a distinguished road
do what i said and call honda and see if it has had the ignition recall fixed. mine was doing the exact same thing. this way you can stop wasting money on stuff that is not needed and a phone call is free.
