Civic not starting
Ok well im back and it is still not starting, the battery is fine, the starter is fine and all of the grounds are good. what is next?
summary- my car wont start but we can push start it and it runs fine. we just dont know the problem. only thing i have done is wire up a sub, which makes no sense.
Possible Idea: ok so whenever i go to start it ill push the clutch in and turn the key and a bunch of the dash lights go off. Now my dad just thought of this ides so we asked my aunt(who has a honda) to do this for us ---> we got her to push her clutch in about half way i guess and try to start the car. her car did the same thing as mine, but when i do mine the clutch is to the floor. my dad thinks that there is like a sensor thing that allows the car to start once the clutch is pushed in a certain amount. has anyone ever had one of these go bad? or are tey adjustable to the point of where it triggers the car to be able to start and maybe i need to re-adjust mine?
sumary- is there a sensor on the clutch pedal area ther tells the car when it can start? like a sensor that once it has ben pushed in far enough it will be able to start?anyone ever had this be a problem?
I know you can disable the switch. Or rather connect it permanently. I've never had a reason to do it. But I imagine its not hard. Just make sure you're not in gear when you go to start it.
Just follow the pedal up under the dash. You have to lay on your back to see it. The nut that holds it on is a 17mm and you will have to use a open end wrench. I just adjusted mine in my Del Sol because I was having to push the pedal in to far to get it to start. The switch dosen't make until you push the pedal in. From there, the Honda book says to screw it in until it touches the pedal arm and then turn in 1/4 to 1/2 a turn. I just adjusted by trial and error. Just adjust the switch where you can get the car to start with a normal leg extension. You can see the electrical plug and nut, but you have to push the pedal in to see the part of the switch that makes contact with the pedal arm.
Good Luck
Teddy
Good Luck
Teddy
Here is the Honda Clutch Adjustment attached.
If you can't read it, email me at teddyg@cox.net and I will send it to you.
