check engine light
Most OBD2 vehicles have two O2 sensors, and will still often run fine with one working and one failing. It will possibly be out of emissions spec though, and may not run optimally for air/fuel, etc., which is why there is a CEL. It's best to replace it for performance and fuel economy.
I'm not sure why it would be flashing. It should just stay on as a solid check engine light and only blink if you are checking the code. Do what they said and check the code yourself or get a scanner run on the obdII port which will tell you a little more specific info.
haha damn i've never seen that on any hondas, but then again very few i mess with actually have cats.
That is all.
Ummm smart guy, the codes are the same in OBDI and OBDII. I think instead of being a smart ass to someone that's been around honda pgmfi longer then you've probably been alive, YOU should be doing the searching. When you are done searching, come back with some accurate information, and we'll have an educated discussion about the differences in OBDI and OBDII.
That is all.
That is all.
Also to add to Nics post, I have seen mutliple misfire's causing that too. Pull out a sparkplug and dont be suprised if there are carbon tracks.
That is all.
That is all.
