Check engine
Old Feb 13, 2006 | 10:46 AM
96CivicHatch's Avatar
96CivicHatch is on a distinguished road
Default Check engine
i was driving in the show when i noticed my check engine light came on. and then my gauges started flashing and then my speedometer just died. it would randomly jump when i shifted, but when i started the car today its stay at zero and the check engine light stays on. the tach still works though. anyone have any ideas how to fix it?
Old Feb 13, 2006 | 12:22 PM
turbobret's Avatar
turbobret has disabled reputation
Default Re: Check engine
sound like maybe the vss but whats the code
Old Feb 13, 2006 | 12:58 PM
whats the VSS?
Old Feb 13, 2006 | 01:00 PM
Hatch Man(GsR)'s Avatar
I drive a coupe
Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR)
The speed sensor located on your transmission. Held on by 2 10mm bolts. Easy fix...
Old Feb 13, 2006 | 01:05 PM
is there any easy way of identifying it, or is there only one wire?
Old Feb 13, 2006 | 01:19 PM
I drive a coupe
It is just to the left of the starter, it is a 3 pin plug that goes straight down and connects to the sensor that is bolted to the transmission. It is hard to miss. Its the big gray one right next to the starter...
Old Feb 13, 2006 | 01:23 PM
thanks ill check it out now
Old Feb 13, 2006 | 04:16 PM
its not it, i checked it and its fine. i also checked my battery and its still blinking and flashing
Old Feb 13, 2006 | 04:57 PM
NastyNate's Avatar
Say somm!!!
NastyNate is an unknown quantity at this point
Since the CEL is on...why dont you pull codes and see what the code is? Being a tech for enough years you usually use the computer of the car to help diagnose CEL/ABS/SRS etc faults. And did you actually remove the sensor and test it with a voltmeter? Or just make sure it was plugged in?
Old Feb 13, 2006 | 06:10 PM
tomorrow we're gonna take it to autozone for a diagnostic test
