changed t.belt/car wont start
i put everything in tdc. i forgot to pt the#1 spark plug back in and only put the wire. i cranked it and the wire spit out and the car bogged. there is spark and gas. i changed the coil in the dizzy. i also changed the cam gears but only the intake side was installed. the stock sticks out a little. why doesnt it start........i put the plug back in so yeah
Re: changed t.belt/car wont start
recheck timing...
will do
There are two things that are really common after changing the timing belt.
1) Timing. Easy to get overconfident and miss something without thinking about it. 2) Spark plug wires. They get taken off, and put back on, and a lot of times they get put back on in the wrong order. |
both above statements....+1
ill take a look
did you reinstall the crank pulley dowel pin thing( real tiny looking rectangle thing, can't remember wtf the name of it is) When you tightened the crank pulley back on?
Originally Posted by team703
(Post 5240115)
