changed t.belt/car wont start
Old 04-30-2009, 10:08 AM
jdmontheway's Avatar
jdmontheway has disabled reputation
Default changed t.belt/car wont start
i put everything in tdc. i forgot to pt the#1 spark plug back in and only put the wire. i cranked it and the wire spit out and the car bogged. there is spark and gas. i changed the coil in the dizzy. i also changed the cam gears but only the intake side was installed. the stock sticks out a little. why doesnt it start........i put the plug back in so yeah
jdmontheway is offline
Old 04-30-2009, 06:23 PM
96civicEK
Trinity001's Avatar
Trinity001 has disabled reputation
Default Re: changed t.belt/car wont start
recheck timing...
Trinity001 is offline
Old 04-30-2009, 07:25 PM
will do
Old 04-30-2009, 07:29 PM
There are two things that are really common after changing the timing belt.
1) Timing. Easy to get overconfident and miss something without thinking about it.
2) Spark plug wires. They get taken off, and put back on, and a lot of times they get put back on in the wrong order.
Old 05-01-2009, 12:20 AM
I <3 My DSM
SPAWN's Avatar
SPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud of
both above statements....+1
SPAWN is offline
Old 05-02-2009, 12:42 PM
ill take a look
Old 05-02-2009, 02:08 PM
team703's Avatar
did you reinstall the crank pulley dowel pin thing( real tiny looking rectangle thing, can't remember wtf the name of it is) When you tightened the crank pulley back on?
team703 is offline
Old 05-02-2009, 02:46 PM
brandon.beene's Avatar
brandon.beene can only hope to improve
my friends car did that same thing, everything was TDC and it still didnt start. The dizzy was not on right, we took it off and we made sure it was on number 1 and it started right up. hopefully that will help you with your situation
brandon.beene is offline
BAN HAMMER
03-23-2009 08:36 AM
gen4H22A
11-23-2008 05:22 PM
sive ick
12-22-2006 02:42 PM
jstabb1
09-12-2006 05:46 PM
HateV8s
02-21-2005 05:05 PM
Quick Reply: changed t.belt/car wont start
