Car wont start. HELP! 94 Stock integra
Its a 1994 Stock Integra LS. When i got it it drove fine, after the first day when i woke up in the morning for work i noticed when i started it it struggled a little for the first id say 3 second until i hit the gas then it was fine. No troubles while driving just on start up. I only drove it for 2 days before i went on vacation for a week, came back and now it just cranks. it does click when i turn the key to on, so i think the relay is fine.. I tried to turn it over today and it seemed to try and bubbled for a second and then nothing. when i tried it a few more times it would start to turn but just do the bogging bubbling instead of kicking over. Any thoughts?
Re: Car wont start. HELP! 94 Stock integra
Check for fuel pressure. If thats good then check for injector pulse from ECU with a noid light. Also check for spark. If you have all of these and compression then I would suspect bad gas. High flow fuel pump without adjustable fuel press. regulator will foul plugs out quickly. Check if the plugs are soaked in gas. goodluck
it is the fuel relay tap the dash where your left knee would be tap the dash while turning the engine over
