Car wont start. HELP! 94 Stock integra
Its a 1994 Stock Integra LS. When i got it it drove fine, after the first day when i woke up in the morning for work i noticed when i started it it struggled a little for the first id say 3 second until i hit the gas then it was fine. No troubles while driving just on start up. I only drove it for 2 days before i went on vacation for a week, came back and now it just cranks. it does click when i turn the key to on, so i think the relay is fine.. I tried to turn it over today and it seemed to try and bubbled for a second and then nothing. when i tried it a few more times it would start to turn but just do the bogging bubbling instead of kicking over. Any thoughts?
Re: Car wont start. HELP! 94 Stock integra
Check for fuel pressure. If thats good then check for injector pulse from ECU with a noid light. Also check for spark. If you have all of these and compression then I would suspect bad gas. High flow fuel pump without adjustable fuel press. regulator will foul plugs out quickly. Check if the plugs are soaked in gas. goodluck
