Car will not turn over...
Old Dec 24, 2008 | 04:57 AM
TurboEGferio's Avatar
TurboEGferio is on a distinguished road
Default Car will not turn over...
So, I just get home from the gym and the car is still running as im just sitting in my car to get out, and then all of a sudden the car just turns off!!! I turned off my turbo timer before I left the gym. I don't even know where to begin with this, and so far I checked all the fuses and wires. They seem to be ok. Does anyone has any input about this? Or had this happen to them? Could this even be a main relay?
This is what it does: When you turn the key you get nothing. There is nothing happening when you turn the car to ACC.
Old Dec 24, 2008 | 11:56 AM
eclispegs2008's Avatar
eclispegs2008 has disabled reputation
Default Re: Car will not turn over...
do the basics first, check the fuses and some grounds. Did you hear anything before it stopped?
Old Dec 24, 2008 | 01:11 PM
b16EFsedan's Avatar
peaches
pull off your dizzy and check it for play. i just had to get a new one after people told me "its a fuse,relay""its outta time" nope the dizzy check it. if its a honda, it the dizzy...but if not is you fuel pump priming?
Old Dec 24, 2008 | 07:28 PM
CHAHONDA's Avatar
corona connessuer
when you turn the key to "on" does the dash light up? or does the car just not crank?
Old Dec 24, 2008 | 07:50 PM
idkmybffEM1ly's Avatar
uhh.. what?
idkmybffEM1ly idkmybffEM1ly idkmybffEM1ly idkmybffEM1ly idkmybffEM1ly idkmybffEM1ly idkmybffEM1ly idkmybffEM1ly idkmybffEM1ly idkmybffEM1ly idkmybffEM1ly
timing belt maybe?
Old Dec 25, 2008 | 05:06 AM
The dash does not light up at all. Like when I used to turn the car to ACC you can here the fuel pump come on, and now it doesnt anymore. Its like the something happen in the dash or something..
Old Dec 25, 2008 | 05:07 AM
The only thing that I noticed is a smell but it didnt smell like something burning or anything..
Old Dec 25, 2008 | 08:16 AM
.eric.'s Avatar
.eric. .eric. .eric. .eric. .eric. .eric. .eric. .eric. .eric. .eric. .eric.
Triple check the fuses, especially the main 50A fuse.
Old Dec 25, 2008 | 11:44 AM
Thanks bro... that was it...
Old Dec 28, 2008 | 02:02 AM
richie-rich88's Avatar
richie-rich88 has disabled reputation
I hope you got your car running by now. If not I would first check your battery connection and if it's ok I would check the ignition switch. I found that with age the wires on the switch get hot and melt the solder were it connects to the switch. Just pull the lower wheel cover and follow the key switch and you'll see where it connects to a bunch of wires. Tug on these wires close to the switch and see if any of them are loose. While you're there use a test light and see if you get power to the switch. good luck
