car way down on power after storage
ATGATT
My car was parked for 10 months. It's a long story, but because this was unplanned none of the things a person does when storing a car were done. The oil was changed prior to starting, and it ran very poorly and slowly. I drained the tank and put fresh gas in. It got some of the power back, but still runs poorly. The cap and rotor showed some signs of wear, so I've ordered a new one and will be changing the spark plugs and fuel filter, but is there anything else that I should be doing? I can't think off what other than fuel would make.A car lose a significant amount of power.
ATGATT
Re: car way down on power after storage
It's a continuous injection system, which makes the injectors far more resistant to that than any pulse injection system.
When I had my injectors cleaned, I was informed to install them within 2 months (or something like that) to keep them from sticking. With your last comment, I dont know how that will apply, but it wouldnt hurt to pull them out and test them.
Edit: What kind of car?
ATGATT
1985 Mercedes 380SE with a 560 motor running CIS KJetronic.Injection, so while not a vw power2weight's instincts are good as it's the same system. I definitely forgot to check the metering plate.
ATGATT
Metering plate moves freely. I pulled a plug and wow those things are fouled up. This car always keeps them clean, even when running so rich it can barely stay running, so I'm thinking it was caused by the bad gas. A closer look at the distributor cap shows some of the contact points are very corroded. So, plan of attack
-change fuel filter, distributor cap, rotor, and spark plugs
-then put Swepco 503 in the tank (apparently this is what Porsche recommends to clean the CIS injection)
and go from there.
and go from there.
ATGATT
Ok, so Cylinder 1 is not getting any spark. I have put in a new cap and rotor (it needed them anyway) and new spark plugs. I tried moving the wires around, still no spark to Cylinder 1. If you hold the wire new something metal, it will arc a spark, but the plug doesn't get any color to it like you would expect a plug that is firing to get.
I'm stumped.
I'm stumped.
