car running too rich
Old Nov 26, 2008 | 07:10 AM
99hatchR's Avatar
99hatchR has disabled reputation
Exclamation car running too rich
all stock injectors, fuel rail, regulator,ecu..etc...except for the fuel pump...car floods on start up...any ideas?...thanks
Old Nov 26, 2008 | 07:32 AM
accuracy1's Avatar
accuracy1 accuracy1 accuracy1 accuracy1 accuracy1 accuracy1 accuracy1 accuracy1 accuracy1 accuracy1 accuracy1
Default Re: car running too rich
Leaky injector.
Is it flooded after sitting all night, but not if you "run into the store"?
Old Nov 26, 2008 | 08:50 AM
4door_GSR's Avatar
4door_GSR has disabled reputation
^like he said it depends on when its flooded ( is it all the time ) could be leaky injector ('s) , could be dad regulater building to much pressure ...... we need mor info to further help
try testing the fuel pressure
Old Nov 26, 2008 | 10:42 AM
Fuel pump might be overloading the regulator. Why do you need an aftermarket fuel pump if you have all of the other stock fuel components?
DisturbedFocus's Avatar
DisturbedFocus DisturbedFocus DisturbedFocus DisturbedFocus DisturbedFocus DisturbedFocus DisturbedFocus DisturbedFocus DisturbedFocus DisturbedFocus DisturbedFocus
what he said.
Old Nov 26, 2008 | 11:20 AM
EH3_SOHC's Avatar
for alarms/rmt-strts
EH3_SOHC has disabled reputation
because he heard it will make you go so much faster.
Old Nov 26, 2008 | 05:02 PM
99hatchR's Avatar
Originally Posted by accuracy1
Leaky injector.
no there isnt a leak...it only floods on start up...
Old Nov 26, 2008 | 05:03 PM
99hatchR's Avatar
i plan on swapping the injectors in the later future...therefore i would need the fuel pump to compensate it for that...
Old Nov 26, 2008 | 05:06 PM
99hatchR's Avatar
no that is not the reason...if you have nothing positive or helpful to say please leave it out of this thread...im not here to cause probs with other ppl...thanks
Old Nov 26, 2008 | 05:38 PM
The stock fuel system can flow quite a bit, usually enough for most N/A use. I I'll bet if you get rid of the fuel pump and go back to stock you won't have to worry about running rich any more.
I guess that I have to ask now, why are you planning on going with larger injectors, are you doing a turbo setup? If you don't need an aftermarket fuel pump for a while, put the stocker back in. It isn't worth the headaches to run different fuel system components unless you have some way of doing, and some reason to do so.
