CA18DET swap
Old Apr 11, 2006 | 09:11 PM
anumeric's Avatar
anumeric has disabled reputation
Default Re: CA18DET swap
just use your ka lower harness. thats what i did and it worked out fine. just swap out the "speedo, reverse, and neutral sensors" from the ka tranny to ca tranny. dont worry about the 4thand 5th gear ka sensor plugs just leave them unpluged. the ka and ca starters have very different positive terminals, just swap the terminals. and for the knock/ detonation sensor "find pin 23 on the ecu and splice it into that wire using shielded wire" if you have the plug for it thats good if not you can solder directly into the knock sensor itself. everything else on the lower harness should be plug and play. i hope this was the info you were looking for if not let us know and well try to help.
wei
Old Apr 12, 2006 | 01:44 AM
one pnt 8 hatch's Avatar
The Dune Coon
one pnt 8 hatch is an unknown quantity at this point
yea its that one plug..... and my lower harness got a lil cut up on the tear out.
Old Apr 12, 2006 | 03:05 PM
The Dune Coon
Old Apr 15, 2006 | 05:25 PM
The Dune Coon
Old Apr 15, 2006 | 05:29 PM
Spindrift's Avatar
psycho jungle cat
I dont know what that plug does but it doesnt seem to matter, ive left it undone on many of my sohc to dohc swaps. So if nothing else I wouldnt concern yourself with that plug.
Old Apr 16, 2006 | 05:41 AM
The Dune Coon
thanks still have no fuel...
Old Apr 16, 2006 | 07:28 AM
-Danimal's Avatar
Boner Jams
looks like we are in the smae boat, but driftek is doing mine. It has fuel but no spark.
Old Apr 17, 2006 | 01:45 PM
The Dune Coon
sucks so... anyone anyother ideas??
Old Apr 17, 2006 | 02:30 PM
sumospeed.com's Avatar
Blang Blang
sumospeed.com sumospeed.com sumospeed.com sumospeed.com sumospeed.com sumospeed.com sumospeed.com sumospeed.com sumospeed.com sumospeed.com sumospeed.com
call driftek,7575476367,jeff said he may make a house call
Old Apr 17, 2006 | 02:32 PM
The Dune Coon
jus to let yall know i got no loot.... im broke looking for a favor...
