brake fluid in oil
#22
Jesus bilt my hotrod
Re: brake fluid in oil
I heard if you put a tea spoon of spermies in each cylinder of a B20B, you can produce little B16's
#23
OV-104
#26
<3's Photography
ATF has more cleaning agents than generic motor oil. 1 quart during an oil change is fine. Make sure u subtract one quart of oil of course.
#27
brake fluid in the oil will usually stop oil leaks. i did on a 87 escort once for shits for a rear main leak and it stopped leaking! 1 year later i sold the car,still see it on the road!!
#30
don't do it bad idea. Me being a mechanic i ve seen and know what happens to those seals. the petorleum base in brake fluid will swell the seals but it will also cause them to rot and fast. i wouldn't do it unless you want to spend severl hundred to several thousand dollar to replace all the engine seals
240dreams
03-11-2008 09:17 AM
