boost problems someone help please!!!1
Old Jun 16, 2005 | 09:33 AM
4drjdmteg's Avatar
4drjdmteg has disabled reputation
Default boost problems someone help please!!!1
Okay i have a question? If my vacum line to my boost gauge has a kink in it will it now allow me to run the amount of boost that my boost controller is set on? My boost gauge will not read over 5 lbs unless my boost is turnd all the way up but if i set it on anything but full boost it will only read 5lbs? why is this
Old Jun 16, 2005 | 10:59 AM
99EJ6T's Avatar
Boosted F2B
Default Re: boost problems someone help please!!!1
umm ur boost guage has nothing to do with how much pressure u run.... it just reads it.
Old Jun 16, 2005 | 11:08 AM
Carter's Avatar
nannerpus, nannerpus
so how high does it go? it could be reaching a certain pressure in the line to un-kink the nylon hose and read actual pressure. but it is just a gauge, it will not make your car boost more or less if something is wrong with your gauge.
Old Jun 17, 2005 | 08:37 AM
4drjdmteg's Avatar
i can only get it to read 5lbs on the guage or it reads full boost could it be a problem with my boost controller this is starting to get annoying
Old Jun 17, 2005 | 10:18 AM
Carter's Avatar
wtf is full boost? what #psi. or does your boost gauge say "5psi"..."half boost"..."full boost"
Old Jun 20, 2005 | 11:54 AM
4drjdmteg's Avatar
okay i am still having the same problem someone told me to t off a line to go from my wastegate to my blow valve and that will fix it is that okay to do on a honda or only dsms
Old Jun 20, 2005 | 12:57 PM
themacuser.org's Avatar
i got 5 on it
themacuser.org is infamous around these partsthemacuser.org is infamous around these partsthemacuser.org is infamous around these partsthemacuser.org is infamous around these partsthemacuser.org is infamous around these partsthemacuser.org is infamous around these partsthemacuser.org is infamous around these partsthemacuser.org is infamous around these partsthemacuser.org is infamous around these partsthemacuser.org is infamous around these partsthemacuser.org is infamous around these parts
take the boost controller out and just run a line straight in place of where it is and see what the gauge reads when you boost on the highway for a while. it'll probably start off at 5 and slowly go up..
Old Jun 20, 2005 | 01:08 PM
4drjdmteg's Avatar
it does but when i had check valves it would read 8 like it was suppose to now i only get the 5 or all of it
Old Jun 21, 2005 | 02:50 PM
Vern's Avatar
turbo on 2 wheels
Vern Vern Vern Vern Vern Vern Vern Vern Vern Vern Vern
your car is a piece of shit and gets beat buy mini-me's all the tyme, and tyler and justins car can whope that ass.
Old Jun 21, 2005 | 04:48 PM
sk8rmike's Avatar
Bitches get Stitches
Tell your sister to quit laggin and get to my house so I can beat that ass up tonight.
