BMW Problem, '04 325Ci not starting or running properly
Old 06-10-2010, 11:06 AM
Default BMW Problem, '04 325Ci not starting or running properly
My BMW-specific knowledge is really limited, so I need help on this one.
I haven't actually been out to look at the car yet, but I want to be armed with enough info to check the likely suspects first. Car belongs to a friend who just bought it and doesn't know much about BMWs yet.
Car was run out of gas about a week ago, because the gauge isn't apparently that accurate at the low end of the scale (or maybe it is, and most other cars aren't?). Filled the car up, let the pump prime, and it started back up after a few tries. Told my friend to change the fuel filter, hasn't had a chance in the last 6 days. No problems until today.
Today, car was stumbling and then shut off. Cranks fine, won't run. I had my friend take off the rear seat bottom to hear if the fuel pump is priming, but it's either not priming or it's too quiet to hear easily with the surrounding noise.
Like I said, I haven't attacked it with my ninja tools yet, so I don't know if the pump is getting power.
So, anyone have any intuition about what it might be? Any typical BMW-specific failure points that I should research and check? I'm going to need to hit the big things in a gas station parking lot, so my access to lots of things might be limited.
Old 06-10-2010, 12:17 PM
I like grape drank
Halfrican's Avatar
Default Re: BMW Problem, '04 325Ci not starting or running properly
BUT BUT BUT!
You're like House?! You're sposed to know everythings!??!?!
Halfrican is offline
Old 06-10-2010, 12:23 PM
Drink Up, Chumps
blah's Avatar
The good news is that the 2.5L in there is pretty much the same 2.5L that BMW came out with in the late 80's. There's no high tech bullshittery, it's just a normal engine.
Is the check engine light on? If so, was on before this incident? The only kinda weird thing is that there's a fuel tank breather valve located in the engine compartment and they have a tendency to do whatever they want (including taking a crap) at any time. It'll set off the CEL and it's about $70 for a new one.
But outside of the feul pump taking a crap, I got nothing. Like I said, it's a pretty basic engine setup and I'm sure you'll be able to track down anything wrong pretty quickly.
blah is offline
Old 06-10-2010, 12:33 PM
No CELs, no nothing. I called around looking for a fuel pump (just to be prepared), and one of the dealerships said the pumps don't like to be run out of gas. So that's a clue. Anyway, in a few hours I'll go check it out.
Old 06-10-2010, 12:36 PM
Fanboi
Cobra4B's Avatar
I mean most fuel pumps are cooled by being submersed in fuel and having fuel flow through them... running them really low or out of gas is akin to running your engine w/o coolant in it for a bit.... no?
Cobra4B is offline
Old 06-10-2010, 12:40 PM
ATGATT
marlinspike's Avatar
marlinspike marlinspike marlinspike marlinspike marlinspike marlinspike marlinspike marlinspike marlinspike marlinspike marlinspike
A superior Mercedes fuel pump is designed as an external pump. Not only does it not hurt them to run dry, but it also allows them to get every last drop out of the tank.
Just saying.
But yeah, in-tank pumps generally rely on being in fuel for cooling. The BMW manuals actually point this out.
marlinspike is offline
Old 06-10-2010, 01:07 PM
NAZI mod
BAN HAMMER's Avatar
this thread isnt real.
BAN HAMMER is offline
Old 06-10-2010, 01:28 PM
SHAKESHAKESHAKESHAKE
Trunk Impaired's Avatar
Tell your friend welcome to the joys of BMW ownership (my sunroof got stuck in the fully open position last night) just take it to the dealership and put his ass out for a pounding when the bill comes back. It's the BMW way. Other than that I'd say read the factory or bentley manual on the car (it's sometimes helpful in diagnosing issues) but yes, running a BMW (or just about any car) completely dry is not good at all. Fuel pump is most likely the culprit, it's the only thing that really makes sense.
Trunk Impaired is offline
Old 06-10-2010, 02:38 PM
the law's Avatar
the law has much to be proud ofthe law has much to be proud ofthe law has much to be proud ofthe law has much to be proud ofthe law has much to be proud ofthe law has much to be proud ofthe law has much to be proud ofthe law has much to be proud ofthe law has much to be proud ofthe law has much to be proud ofthe law has much to be proud of
Have you checked the Fuel pump relay? Use a jumper wire from pin 30 to 87, that should tell you if the relay is bad or not because that will give you power to your fuel pump. That way you can crank it and drive it home. If that's not the case then check the DME relay. I'm currently going through a similar situation but with a little twist. Let me know if that doesn't help, I can at least guide you in the right direction if I don't have a solution.
the law is offline
Old 06-10-2010, 03:58 PM
the law's Avatar
Ohh I read it wrong, it might not be pin 30 and 87, I know it is for e36's but I'm pretty sure it'll do the same thing.
the law is offline
Quick Reply: BMW Problem, '04 325Ci not starting or running properly
