Bigger throttle body=smoke?
Old 03-11-2007, 06:09 AM
neg rep this!
94accord's Avatar
94accord has disabled reputation
Default Bigger throttle body=smoke?
Problem solved! Close thread
94accord is offline
Old 03-11-2007, 07:48 AM
OV-104
Atlantis's Avatar
Default Re: Bigger throttle body=smoke?
color of the smoke?
Atlantis is offline
Old 03-11-2007, 04:16 PM
neg rep this!
94accord's Avatar
black
94accord is offline
Old 03-11-2007, 06:08 PM
GST342hp's Avatar
GST342hp is an unknown quantity at this point
Hope you didn't actually hook one of the evap or fuel lines into a coolant port or vice versa. I've seen it happen.
GST342hp is offline
Old 03-11-2007, 06:20 PM
integrarj's Avatar
its your map sensor, not gettin enough vaccum. mine did the same cause i forgot to put the lil o ring on the tb under map sensor
integrarj is offline
Old 03-11-2007, 10:59 PM
neg rep this!
94accord's Avatar
No, the throttle body doesn't even have coolant ports. And also the map sensor bolts to the bottom now and not the top.
Damnit man, i think your right because there was a port for a vacuum line on the old throttle body that doesn't even exist on the new one. this throttle body only utilizes the map sensor and the idle sensor and that's all. But i didn't forget any o-rings tho. So, i guess there's no way to fix this but to take it off? Do you have a skunk2 throttle body also?
94accord is offline
Old 03-12-2007, 05:06 AM
integrarj's Avatar
no i dod it on my boys 93 lude. the place for the map sensor is under the TB. extend the vacum hose that is hooked to your map sensor and stick it in the hole where the map sensor goes on the TB, should be a tight fit. give me a call if you have anymore problems, we can take car of it for you at my shop if needed. Redline customs: 804-317-4760
Old 03-12-2007, 10:05 PM
neg rep this!
94accord's Avatar
You were right. I forgot to put the frickin o-ring on! Thanks a lot yo, i owe you one. And thanks to everyone else also for your input.
94accord is offline
Old 03-13-2007, 01:38 AM
neg rep this!
94accord's Avatar
Do you guys tune? If so, how much?
94accord is offline
Old 03-13-2007, 04:54 AM
integrarj's Avatar
pmed
Quick Reply: Bigger throttle body=smoke?
