Battery keeps dying?
Old Oct 1, 2004 | 10:11 AM
Crate's Avatar
poop
Crate Crate Crate Crate Crate Crate Crate Crate Crate Crate Crate
Default Battery keeps dying?
I have been through 2 batteries in 2 weeks. Altenator tests at 12.5 output... possible problems?
Old Oct 1, 2004 | 10:13 AM
travisnd's Avatar
VA
travisnd travisnd travisnd travisnd travisnd travisnd travisnd travisnd travisnd travisnd travisnd
Default Re: Battery keeps dying?
Something electrical possibly?? Sounds like a similiar problem I was having with the Prism.
Old Oct 1, 2004 | 10:27 AM
PJ2's Avatar
PJ2
PJ2
Your alternator should be putting out at least 13.5V not 12. Try this test, read the voltage at the battery with the engine not running and then againg with engine running, it should be at least 1.5 V higher with the engine running and if not it's a bad alternator and you should get it tested. Pep boys and Advanced auto will test it free of charge.
Old Oct 1, 2004 | 10:34 AM
montman's Avatar
Biding time
montman is infamous around these partsmontman is infamous around these partsmontman is infamous around these partsmontman is infamous around these partsmontman is infamous around these partsmontman is infamous around these partsmontman is infamous around these partsmontman is infamous around these partsmontman is infamous around these partsmontman is infamous around these partsmontman is infamous around these parts
Yeah he is right, I had a problem with my old beater 89 accord the it was registering 12.5 and losing batt power, replaced the alt, and it read a consistent 14.X.
Old Oct 1, 2004 | 08:25 PM
Skywalker's Avatar
Atheist.
Skywalker Skywalker Skywalker Skywalker Skywalker Skywalker Skywalker Skywalker Skywalker Skywalker Skywalker
Problem: your name is Crate.
J/K....those guys are right. The guys at Advanced love to wheel out the voltage cart. then again, you're now living in the middle of sand and water, right? Best of luck bud.
Old Oct 2, 2004 | 04:17 PM
Most likely a bad regulator, and if it's built in (most are), get another alternator. This is one of the reasons that a lot of aftermarket alts have an external regulator.
Old Oct 2, 2004 | 04:46 PM
NIC668's Avatar
you been pm'd
Old Oct 8, 2004 | 05:30 PM
civic1987's Avatar
civic1987 is an unknown quantity at this point
hey i have replaced my battery and alternator twice and the it is still giving me prob. u think that it is a bad wire from the alternator to the battery........if anyone has any ideas............pm me back, thanx
Old Oct 26, 2004 | 12:57 PM
civic1987's Avatar
hey maybe ur wiring harness to the alternator is bad.....the alternator could be putting out 12 out of 14 amps............but its suppose to be putting 60 volts. mine was putting 12/14 amps but only 2 volts..so i had to replace the alternator wiring harness
Old Oct 26, 2004 | 04:00 PM
Crate's Avatar
poop
i forgot to post, it was my alarm. it went bad.
