b16a2 engine surging problem
Old Dec 11, 2004 | 02:00 PM
SwtNLow04's Avatar
SwtNLow04 has disabled reputation
Default b16a2 engine surging problem
hey i have a 99 si and at 1900 rpms the engine wants to surge does anyone know anything about this.
Old Dec 12, 2004 | 10:23 AM
Hybrid_vtec's Avatar
Nonvtec owns you
Hybrid_vtec has disabled reputation
Default Re: b16a2 engine surging problem
what do you mean surge; at idle?
Old Dec 12, 2004 | 12:27 PM
HatefulMechanic's Avatar
The Pro to call.
what kind of CAI do you have?
check your coolant level.
Old Dec 12, 2004 | 12:35 PM
gear's Avatar
Die reinste Bösen.
IAC
Old Dec 13, 2004 | 01:59 AM
SwtNLow04's Avatar
it doesnt surge at idle just at 1800, 1900 rpms. an like the engine is just jumping back and forth. it has a aem cold air intake on it. an when you start it up it will idle kind of low. thanks
Old Dec 13, 2004 | 02:04 AM
c1t1d1's Avatar
c1t1d1 is an unknown quantity at this point
i would tell you to check the idle control sensor but i think yours is a throttle cable. Try adjusting the idle up to 750 -1000 were it should be.
Old Dec 13, 2004 | 04:17 AM
The Pro to call.
how would IAC or throttle cable adjustment affect the engine operation at 1900 rpm
Old Dec 13, 2004 | 04:22 AM
c1t1d1's Avatar
Im just saying that i have a exploer sport trac and same thing happend to me. I would be driving or sitting at a light with foot on brak and the car woudl drop to like 500 rpm and up to like 2000rpm, th throtle control sensor was bad. Just giving you ideas.
Old Dec 13, 2004 | 08:31 AM
The Pro to call.
fords are notorious for having IAC issues.....but this guys complaint is at off idle....which is not controlled by that.
although, there really isnt enough info from the guy to tell, but it is a possiblity there is a slight misfire, or a hiccup in the TPS voltage..
Old Dec 13, 2004 | 11:38 AM
SwtNLow04's Avatar
thanks for all the info but its fixed and it was the iac
