B16A to an EJ8
I'm thinking about swapping an ODBI B16A from an SIR I into my 1998 civic EX
the swap comes with the entire motor, tranny, and ECU it does not come with axels or mounts, the place i'm thinking about getting it from is noyan in manasas. this is not set in stone because i'm still considering my options, but i just want to know what all would i need to do |
Re: B16A to an EJ8
You will need a obd2-obd1 harness. Also you will need the rear mount AND bracket (I have heard that the rear mount on the sohc and dohc are slightly different). 50810-ST7-000 < 99-00 SI,; 50810-SR3-030< 96-98 civic ex. The Rear T bracket, and the driver's side bracket is also needed. Maybe a b series shift linkage if it doesn't come with it. and axles
thats all i can think up |
Re: B16A to an EJ8
talk to Jay (vr4-ever) about an adapter harness if you need one..
Re: B16A to an EJ8
you will also need to do some re-wiring to the harness. (injector plugs need to be swapped, and maybe a knock sensor needs to be wired.)
Re: B16A to an EJ8
What would you guys recomend? axel wise, dc2? si?
i think i'm going to get a hasport mount set and i'll go to the junkyard for the shift-linkage i saw a wireharness conversion thing on kingmotorsports.com what exactly would i need for that? |
Re: B16A to an EJ8
Re: B16A to an EJ8
and if your getting the full swap from noyan it comes with ecu, axels, shift linkage and jdm wiring harness, and some mounts. Thats where my swap came from and i got everything i needed exept for the rear T bracket.
Re: B16A to an EJ8
Re: B16A to an EJ8
Originally Posted by Lord_Vegeta
Not really! Noyan doesn't send the axles & mounts sometimes. I've dealt with them on a couple of swaps so I know first hand. How about you go to Hmotors & buy the complete swap over? |
Re: B16A to an EJ8
From a '99-'00 Civic Si you'll need:
-axles -throttle cable -throttle cable bracket -All three main mounts (unless you'll be using HASports) -Rear mount bracket Since it's an OBD1 swap you'll need to either: -Rewire the distributor and alternator plugs on your harness OR obtain OBD2 versions of each Also, since the ECU is OBD1, and your car is OBD2A, you'll need to either: -Obtain an OBD2A-OBD1 jumper harness (got mine from "Boomslang" on honda-tech) OR get someone (I hear VR4-EVER is good at this sort of thing) to rewire everything on your chasis harness You'll also need b-series shift linkage. I think that's the main points for the swap. |
| All times are GMT -8. The time now is 05:22 AM. |
