b16 head and GSR head
Old May 17, 2005 | 07:26 PM
94_CRVtec's Avatar
94_CRVtec has disabled reputation
Default b16 head and GSR head
is there any true difference between the two heads? I have heared that the B16 head flows better, but then again i have heard that there is really no eifference at all...
Old May 17, 2005 | 08:12 PM
MORE IMPATIENT's Avatar
DESTROYS DONUTS !!
Default Re: b16 head and GSR head
apparantly the b16 head does flow better, the MAJOR difference to me is that you can use a Type r intake manifold on the b16, you cant use it on the gsr, the Type r intake manifold is the best flowing honda manifold of all so the fact that you can use it on a b16 head is a big advantage, if you want a better flowing manifold for the gsr, you have to go aftermarket.....
Old May 17, 2005 | 08:44 PM
94_CRVtec's Avatar
well i have an aftermarket on my b16 now, but im building a b20vtec turbo and not sure if i want to go with b16 head or gsr head, i have been told that the difference in the two would be so small that i would never notice
Old May 17, 2005 | 09:49 PM
ef_what?'s Avatar
representyoshit
ef_what? is infamous around these partsef_what? is infamous around these partsef_what? is infamous around these partsef_what? is infamous around these partsef_what? is infamous around these partsef_what? is infamous around these partsef_what? is infamous around these partsef_what? is infamous around these partsef_what? is infamous around these partsef_what? is infamous around these partsef_what? is infamous around these parts
i heard that the combustion chambers are shaped differently as far as size and the quench area, so the compression will differ as well as the flow to the valves.
Old May 20, 2005 | 04:55 PM
black6gen's Avatar
Turbo VTEC-E
black6gen can only hope to improve
Thats what I've heard.
Old May 22, 2005 | 09:35 PM
94_CRVtec's Avatar
so then the aftermarket b16 intake mani i have, wont fit on a gsr head...right
Old May 22, 2005 | 09:51 PM
Keepin it Klean's Avatar
Clean Freak.
Keepin it Klean Keepin it Klean Keepin it Klean Keepin it Klean Keepin it Klean Keepin it Klean Keepin it Klean Keepin it Klean Keepin it Klean Keepin it Klean Keepin it Klean
really depends on what cams and intake manifold your using.
edit for link: http://www.importreview.com/reviews/...sB16Ahead.html
Old May 23, 2005 | 12:10 AM
sk8rmike's Avatar
Bitches get Stitches
gsr yields slightly higher compression stock, b16 head flows a little better. i'd say the b16 head is the better head overall although if you start getting into headwork and aftermarket parts it really doesnt matter which you use.
Old May 23, 2005 | 08:04 AM
CRX's Avatar
CRX
CUMNURI
CRX is an unknown quantity at this point
Get a gsr head, then sell me your intake manifold cheap. just my opinion
Old May 23, 2005 | 11:15 AM
99EJ6T's Avatar
Boosted F2B
, but if you do alterations to the head (grind/port/etc) then it really doesn't matter unless you plan on making a drag/race motor. then i would go with the gsr head, just my opinion.
