B series idle problems
Re: B series idle problems
could be a bubble in the coolant as well. look for any opend valves on the IM. aka if you see a hole put your finger over it. if it stops bouncing you found the problem.
try taking you IAC valve off, it is located on the back of your intake manifold. try cleaning the screen on it with carb cleaner and spray the carb cleaner in the other hole also. if it still occurs try replacing your IAC. same thing happened to me.
Originally Posted by Sickteg24
yea i was thinkin IAC. thanks for the advice i'll try cleaning it. by the way my car is OBD1.
