Auto tranny problems
Old Dec 28, 2008 | 06:06 AM
b16 snatch's Avatar
Captain Deeeez Nutzz
b16 snatch has disabled reputation
Default Auto tranny problems
Hi all
I am not familiar with automatic transmissions and I'm having problems with one in my 92 civic.
I was driving on the interstate and all is fine then nothing. It's like I'm in neutral. I pulled over, verify that I am in D4 and start from a stop. It accelerates but wont shift to second gear. I let off the gas for a second then try again and it's just completely out of gear. I pull over again and put the gear selector in 2 and I am able to limp home at 25 mph. I checked the ATF fluid level once home and it was low. I filled it to the full line and I am still having the same issues.
To summarize:
Car will accelerate in D4 from a dead stop but wont shift out of 1st unless I take my foot off the gas, then it just falls completely out of gear into what feels like neutral.
I am able to put the gear selector in 1 and 2 and accelerate in those gears.
Is it the transmission itself or the torque converter? Like I said I am very much a noob when it comes to an auto transmission.
Thanks for the help
Old Dec 29, 2008 | 05:08 AM
b16 snatch's Avatar
Default Re: Auto tranny problems
Old Dec 29, 2008 | 05:12 PM
John M's Avatar
John M John M John M John M John M John M John M John M John M John M John M
sounds like you need a new tranny
Old Dec 29, 2008 | 05:33 PM
EF8SohcMan's Avatar
EF8SohcMan is a name known to allEF8SohcMan is a name known to allEF8SohcMan is a name known to allEF8SohcMan is a name known to allEF8SohcMan is a name known to allEF8SohcMan is a name known to all
deffinately transmission. and if ur replacin the trans u might as well get a torque converter while the trans is out any way its no telling how long the converter will last. knock it all out at once.
Old Dec 29, 2008 | 05:47 PM
b16 snatch's Avatar
thanks for the info so far, any other input?
Old Dec 30, 2008 | 08:45 AM
b16 snatch's Avatar
up ^
Old Dec 31, 2008 | 07:11 AM
b16 snatch's Avatar
Old Dec 31, 2008 | 02:01 PM
HighPSI TSi Guy's Avatar
❒Good ❒ Better ✔Best
Overdrive clutch is toast.
Have fun. Any trans other than a honda it'd be a simple fix.
Old Jan 3, 2009 | 05:33 AM
b16 snatch's Avatar
is that in the transmission or part of the torque converter?
Old Jan 3, 2009 | 11:21 AM
It's on the back of the rear (2nd gear) drum on most honda trannies, dead center in the middle of the trans. When you put it in 2 you are avoiding overdrive so you avoid the "neutral" gear. Your front clutch could be toast too, but I'm pretty sure on a honda the toasted OD clutch will fuck it all up. The later ones it does for sure, not sure about your year. Most likely need to replace all the clutches in it. Parts are cheap but labor is not.
