another a/c questions! please help
Old Jun 8, 2007 | 03:57 PM
CTR's Avatar
CTR
ACCOUNTANT
CTR has disabled reputation
Default another a/c questions! please help
i got it flushed, vacuumed, charged. but i feel as thought its not as cold as it should be while at a stop. it blows cool, maybe 77ish; when its like 95 outside. very cold when at a stop @ night. its gets very cold, below 65 degrees, when 40mph+. what could it be?
also theres condensation on the low side lines. is this normal?
PS: fans works when a/c is turned on. no debree on condenser fins.
thanks!
Old Jun 8, 2007 | 04:45 PM
HatefulMechanic's Avatar
The Pro to call.
Default Re: another a/c questions! please help
why was it flushed?
what was the original complaint?
was there a compressor failure?
was the x valve replaced?
is the correct amount of refrigerant installed?
was it diagnosed correctly to start?
low side pressure at idle? 2500?
high side pressure at idle? 2500?
vent temp?
temp drop across condenser?
temp drop across evaporator?
airflow across condenser?
airflow across evaporator?
just a few questions a good AC man will find the answers to.....
Old Jun 8, 2007 | 05:18 PM
CTR's Avatar
CTR
ACCOUNTANT
why was it flushed?
lines left in garage ie dust, moisture
n/a
used system put in
yes, as recommended by you! in my other post. thanks!
i believe so
yes
not sure what you mean by 2500 but its around 43 psi
vent temp?
77-80 ish @ a stop, 96 degree outside. below 65 when driving 40+mph
not sure how to check
not sure
looks good to me?
cleaned out all debree when change x valve.
PS: condensation on the lines normal?
is it possible that the blower has too much debree in it? sounds weird but i read it off honda-tech. all your help is appreciated!
Old Jun 8, 2007 | 05:22 PM
CTR's Avatar
CTR
ACCOUNTANT
pmed you also!
michael-17
Jul 22, 2008 08:55 AM
Dmac
Oct 8, 2007 09:26 AM
H22blkaccord20
Aug 24, 2006 05:10 PM
2003gt
Aug 17, 2003 08:51 AM
