Air to water, or Air to Air?
Team Rad Racing
Im changing my motor setup and I am in the air as to whether go with an air to water intercooler setup, or go with a bigger air to air setup. Opinions are welcome with some sort of reason as to why you think I should go one way or the other. Thank you ahead of time.
Re: Air to water, or Air to Air?
Air to air is easier to make efficient and usually way cheaper. You can get a lot of bang for your buck with a front mount air/air setup and there's no maintanance and nothing to fail really. You add more weight, complexity, and cost with an air/water setup, and there are more things to fail. That's not to say there aren't some good reasons to have an air/water setup, but for street cars it's a hard thing to justify. You have to have a radiator, charge cooler, header tank, pump, coolant lines, charge tubing, etc. instead of just the intercooler and charge piping for something like a front mount air/air.
It really depends on the setup and the car, but I'd find it hard to lean on the side of the air/water for most situations. It's just really hard to beat an air/air for efficiency most of the time..
That being said, I'm going to replace my top mount WRX intercooler with a air/water unit this summer if I can scrape the money together. Why? I like to fabricate stuff.. If I were sane I'd just buy a bigger top mount or front mount like the rest of the world.
So to answer your question, my opinion would be a bigger air to air setup..
Drink Up, Chumps
Is it for your hatch? And do you even drive it on the street anymore or is it just a drag car?
Wanna fab me up a c/f roof?
Dead serious.
Dead serious.
Team Rad Racing
I also know that air to water is not really good for driving on the street because the water heats up. I figured if i had a decent heat exchanger and a nice size resevoir to hold more water that i wouldnt have that problem. I mean Josh MR2 2NR didnt have a problem and the superchargers for s2ks have air to water intercooler setups. The only downside im seeing is having a water tank somewhere. But thats also why i made this thread to see if there is more to it that i do not know about.
You'll need more than an oil cooler, a small radiator is really better. Oil coolers are meant for thicker liquids; they don't have the same thermal efficiency with water because the passages are bigger and the water goes right through without giving up its heat.
The air/water intercooler itself is fairly $$, I've never figured out why though.
I always vote Air to Water if you are running hot air. Yeah air to air is easy and can be dirt cheap, but air to water isnt as "$$" as most thing. You can place the core anywhere you want vs in the front of the vehicle or an area of cool air flow- much less charge pipe to worry about. Its a million times easier to run 1" water lines threw an engine bay than it is to run bent metal 2-3" pipe. You can cool a charge much better with air to water due to the ease of iceing a reservoir.
All in all it just depends on budget, and what type of parts you are looking for. Yeah a bling water to air is going to be $$ but you could make one for cheaper than your off the shelf greedy/hks/etc. front mount kit.
Consider this one vote water to air, not to say I dont think air to air is efficent or smart, both have alot to say for themselves..
卐 Walnuts
air to water i always thought of it being good for high HP drag cars or supercharged cars...you can just do AIR to AIR with the water spray or spray juice into the fmic
