AC.. Car problem...
Old Jun 21, 2008 | 09:00 AM
jdm_dc4r's Avatar
jdm_dc4r has disabled reputation
Default AC.. Car problem...
When my car is cold and the ac is turn on the car doesn't die, but after when it warms up and the AC blowing and then press on gas the car dies. Anyone know the problem>>>>????
Old Jun 21, 2008 | 09:00 PM
atmdc's Avatar
やくざに成りたい
atmdc has disabled reputation
Default Re: AC.. Car problem...
sounds like an issue with idle, because when the car is cold it idles higher, but after it warms up your idle should drop around 750 or so and then when you cut your a/c on it will drop a little bit more. does it always die or just sometimes? check your idle rpm
Old Jun 21, 2008 | 09:51 PM
DeFunk's Avatar
DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk
Did you just happen to put more refrigerant in your system?
Old Jun 21, 2008 | 10:20 PM
ethan82000's Avatar
ethan82000 has a reputation beyond reputeethan82000 has a reputation beyond reputeethan82000 has a reputation beyond reputeethan82000 has a reputation beyond reputeethan82000 has a reputation beyond reputeethan82000 has a reputation beyond reputeethan82000 has a reputation beyond reputeethan82000 has a reputation beyond reputeethan82000 has a reputation beyond repute
ide say to much refrigerant
Old Jun 22, 2008 | 09:00 AM
jdm_dc4r's Avatar
It will always die when the car is hot and I haven't even touch the AC since I swap in my motor. any more thoughts of how I can fix it?
Old Jun 22, 2008 | 09:12 AM
DeFunk's Avatar
If you run your car long enough for your radiator fan to come on, without any loads (ie. no booming system playing, no A/C, no turning the steering wheel and no braking, no lights, etc.) how is your car idling?
Once you've checked the idle, turn on your A/C, is your condenser fan coming on?
The A/C compressor puts a good deal of strain/resistance on the engine, thus the reason why gas mileage with A/C is poorer than that with it off.
Will wait for response to PM before I go further.
Old Jun 22, 2008 | 09:15 AM
jdm_dc4r's Avatar
If I let the car idles until the fan come on and with nothing on the car will idle almost at 1,000rpm.
The other thing is that I dont have an AC fan will that affect anything??
Old Jun 22, 2008 | 09:26 AM
DeFunk's Avatar
Yes, your condenser needs a fan. That is very likely your problem, the refrigerant is hot, thus expanded in the lines, thus placing a huge amount of stress on your A/C compressor, which means a much bigger load than it is supposed to apply to your engine.
Old Jun 22, 2008 | 09:29 AM
jdm_dc4r's Avatar
Alright, I'll update you on it. I'm going to go put on the fan and see if it still dies. Thanks though..
Old Jun 23, 2008 | 10:59 AM
jdm_dc4r's Avatar
Hey, Just wondering if my distributor is bad will it caused my car to die when AC is on and press on gas slightly and will it caused my car to be off timing when EVERYTHING IS TOP DEAD CENTER???
