99 Si Idle Air Control Problem
Old Aug 5, 2007 | 09:28 AM
Polow da Don's Avatar
BLACK&YELLOW
Polow da Don has disabled reputation
Default 99 Si Idle Air Control Problem
So check engine light came on and I took it to Advance to run a test and it come back as an IAC malfunction. I took it off, cleaned it with break cleaner let it dry completely. Put it back on and everything was gravy for a bit then the check engine light came back on. So I got a used one, put it on, (cleaned it before hand) and the check engine light is back on. The car has a high idle (1100-1500 range) and runs like shit after about 10 mins of driving.
Am I missing something?
Old Aug 5, 2007 | 05:36 PM
Dang Yo's Avatar
Justa lil 6
Dang Yo is a jewel in the roughDang Yo is a jewel in the roughDang Yo is a jewel in the roughDang Yo is a jewel in the roughDang Yo is a jewel in the rough
Default Re: 99 Si Idle Air Control Problem
idle air control valves once cleaned will only last a week or two. time for a brand new one.
Old Aug 8, 2007 | 02:04 PM
BLACK&YELLOW
But what are the chances that the used one we got was fucked up as well? Ill try another used one and see where that gets me.
Old Aug 8, 2007 | 02:18 PM
oldbodyb16's Avatar
oldbodyb16 is infamous around these partsoldbodyb16 is infamous around these partsoldbodyb16 is infamous around these partsoldbodyb16 is infamous around these partsoldbodyb16 is infamous around these partsoldbodyb16 is infamous around these partsoldbodyb16 is infamous around these partsoldbodyb16 is infamous around these partsoldbodyb16 is infamous around these partsoldbodyb16 is infamous around these partsoldbodyb16 is infamous around these parts
yea chances are that one was bad to there kinda funny after they sit around they like to stick
Old Aug 9, 2007 | 07:23 PM
1slowcivic's Avatar
1slowcivic 1slowcivic 1slowcivic
don't buy use parts as oldody16 says buy new factory iac
Old Sep 21, 2007 | 08:01 AM
BLACK&YELLOW
Get this hoe to the top cause after installing a BRAND NEW IAC, the check engine light is back on. It is throwing the same code at that. Insight please?
Old Sep 21, 2007 | 02:02 PM
Possible ECU or wiring problem, or connector corrosion. Borrow an ECU and see what happens, inspect the connector, and do a continuity check from the ECU to the sensor. If the ECU has been taken out of the car ever, look to see that the IACV contact pin didn't get misaligned and shoved out of the connector housing.
cleanEK
Sep 25, 2007 07:10 PM
Will Sol
Feb 24, 2006 02:11 PM
